FLEx 6300 RX signal attenuation
Gary Clarke
I use a flex 6300 and today when turning the radio on i noticed that the noise and signals were about 20-30db down on what i would normally expect to see. Same on different bands / antennas. Transmit is fine, problem is just with receive. Ive seen various threads about this problem but doesn't seem to be clarity about what as resolved this issue. Any feedback would be appreciated.
Is there a question? comment? Gary
Hi Gary
Can you post a screen shot of SmartSDR showing all the controls? That helps us see what your settings are.
Are you sure you have both Transmit and Receive antenna as the same?
Mike0 -
Hi Mike, its happening on same transmit / receive antenna. Ant 1= 40 meter yagi, Ant 2= 10 meter vertical. Nothing as changed with radio settings since i used the radio yesterday. normally at this time of the evening scope is populated with lots of signals. friend and i worked New Zealand on 40 metes earlier, i couldn't hear him and my friend 5 miles away worked him fine. same is happening on 10 meters my noise floor as dropped dramatically and local signals are down by about 4 s points. different antenna obviously. Transmit signal is fine, please see attached photo0
Are you sure you don't have an antenna issue? It could have a good SWR and still be bad. Similar to a dummy load. Maybe a questionable patch cord.
BTW, your AGC-T is at 100%. For 40M, I would expect it to be set about 30%.
The photo is pretty small and hard to read the settings.
What I would do is export your profiles to save them and then reset the radio and test again.
Maybe someone else can see something out of place.
Mike0 -
It looks like he has everything set for max in order to hear the best. I would also suggest to do radio reset. I would just do a factory reset, then import your profiles back.
Ok, I've carried out further experiments and it appears that when i change the rx antenna on 40 meters from ant 1 (40 meter beam) to ant 2 (10 meter vertical) there is no difference in rx signal.same applies when i'm on 10 meters and switch to the 40 meter beam, it makes no difference to the rx signal so i'm getting somewhere. Its like its stuck on the same antenna but with attenuation thrown into the mix as well. neither antennas are receiving like they should on either band
Hi Mike, the 40 meter antenna goes to ant 1 via an amplifier, the 10 meter antenna goes straight into ant 2 on radio. also tried both antennas into back of rig. Please see comment i made below ref the changing of rx antenna not making any difference to rx signal.0
Did you reset the radio yet?0
ESD, Electrostatic Discharge Device bad?0
Hi Mike, i did a reset and its made no difference. signals are all down on rx regardless of antenna. swr great on both antennas and tx performance isnt affected. My local 10 meter beacon is normally s5 today its s1. Its like a attenuation swich as been turned on, but i can only alter the RF GAIN on the antenna switch on left hand side, is this right ?0
Gary, I have a similar issue that occurs on 40 meters. Here is a video describing the issue and what I can do to resolve it. Perhaps this will help you ? I have opened a ticket with Flex support and it is documented as a software defect. -Joe N3HEE
https://www.youtube.com/watch?v=_rkHuF64wMA&feature=youtu.be
Hi Gary
If you have eliminated the environment as the problem, then you will need to open a support case. Depending what they find out, you may have to send it in for service.
Do you have a signal generator at all?
I have converted this to a support case.0
Thank you Mike0
Hi Joe, thanks thats really interesting. My problem is on different bands with different antennas and won't fix by alternating antennas like yours did. I've just had a support case opened so hopefully we can get it sorted quickly.0
- 322 Community Topics
- 587 The Flea Market
- 7.8K Software
- 6.2K SmartSDR for Windows
- 390 SmartSDR for Mac
- 256 SmartSDR for iOS
- 245 SmartSDR CAT
- 177 DAX
- 368 SmartSDR API
- 9K Radios and Accessories
- 12 Aurora
- 144 FLEX-8000 Signature Series
- 903 Maestro
- 50 FlexControl
- 860 Genius Products
- 443 Power Genius XL Amplifier
- 303 Tuner Genius XL
- 114 Antenna Genius
- 272 Shack Infrastructure
- 192 Networking
- 435 Remote Operation (SmartLink)
- 135 Contesting
- 709 Peripherals & Station Integration
- 131 Amateur Radio Interests
- 935 Third-Party Software
