Need to know the my default Mic EQ and PR781 EQ Settings.
Julie KC0TMD
Hello,
It seems that I got the default Mic EQ and PR781 Mic EQ Settings all messed up. Can anyone kindly provide a posted photo of what the settings of the EQ for Default Mic and PR781 Mic Settings at factory default look like. Just hate to have to factory reset the Radio to get them back to what they should be from the factory. Sorry as this is a sloppy operator error.
Thank You.
Thank You.
Hi Julieber1,
I would suggest that you bite the bullet. Export any profiles that you may have and do a factory reset. That way you will get the default mic settings for your radio.
When you import your saved configuration, select all buttons except MIC profiles. Now you should have the default mic profiles available. In profile manager, select the tab Microphone and scroll down to the default mic that you want. A double left click on any mic will show the EQ setting for that mic in the P/CW pane on the right side of the main screen.
If you make any changes to the profiles, don't forget to save and export so that you save the changes.
Hope this helps,
Roy - W5TKZ1 -
Julie. you can right now go into profiles. profile manager, then Microphone. In there you will find the mic profile for the 781
Not if he deleted it which I am assuming is what he is saying as he mentioned resetting the radio to get it back.
Those default profiles should not be deleted, that would take a little works to do. Many people do not know all those default mic profiles are even there. They come standard with all SSDR installs.
Not sure why you say that. I disagree. I delete everything I have no chance of using. Why have to scroll through dozens of mic choices each time you use it.
I delete all the SO2R stuff too. No reason to keep it.
Ok Rich, have it your way,,no problem
Julie, here is the PR 781 settings.
-1 -
Bill not trying to offend you. Just did not agree. That's all. I personally don't like to have extra stuff in the drop downs
I was just trying to help someone, not everyone deletes every default profiles, I was hoping that in her case. She may not be aware they are there.
Also as a side note, anytime you create a profile they are found at the top of the long list so they are really easy to find.0 -
I agree with all of that.
And you are always very helpful. No exception here.
Trying again,,the PR 781 settings
And NO bias of course.1
- 247 Community Topics
- 488 The Flea Market
- 7.4K Software
- 330 SmartSDR for Mac
- 241 SmartSDR for iOS
- 224 SmartSDR CAT
- 161 DAX
- 344 SmartSDR API
- 8.5K Radios and Accessories
- 773 Maestro
- 42 FlexControl
- 727 Genius Products
- 252 Tuner Genius XL
- 84 Antenna Genius
- 224 Shack Infrastructure
- 151 Networking
- 372 Remote Operation (SmartLink)
- 118 Contesting
- 116 Amateur Radio Interests
- 810 Third-Party Software
