wsjt-x logging to HRD via JTAlert
DL Eddy
DL Eddy Member
edited January 2020 in FLEX-6000 Signature Series
Using WSJT-x and JTAlert with HRD on Flex 6400. Had JTAlert auto-log QSOs to HRD Logbook. Install Slicemaster 6000, which now allows HRD to track Slice frequency (Good), but logging via JTAlert no longer occurs. Any info on what I have missed or mis-configured?
  • Alan
    Alan Member ✭✭✭✭
    edited January 2020
    I set mine up the same way using Slice Master, eliminating the HRD middleman for logging.
    You can use UDP send from WSJT-X directly to HRD log.
    In WSJT-X settings / Reporting, click the box for "enable broadcast for ADIF broadcast:  Make sure the port numbers are the same for both:
    In HRD Log, go to tools/QSO Forwarding and click the box to receive UDP broadcasts from WSJT-X.  Select which log database to use.    Make sure the port numbers are the same for both:
    Alan
    WA9WUD
  • DL Eddy
    DL Eddy Member
    edited January 2020
    Thanks  Alan, sounds like the best way forward, 73
    Don AA5DE
