wsjt-x logging to HRD via JTAlert
DL Eddy
Member ✭
Using WSJT-x and JTAlert with HRD on Flex 6400. Had JTAlert auto-log QSOs to HRD Logbook. Install Slicemaster 6000, which now allows HRD to track Slice frequency (Good), but logging via JTAlert no longer occurs. Any info on what I have missed or mis-configured?
I set mine up the same way using Slice Master, eliminating the HRD middleman for logging.
You can use UDP send from WSJT-X directly to HRD log.
In WSJT-X settings / Reporting, click the box for "enable broadcast for ADIF broadcast: Make sure the port numbers are the same for both:
In HRD Log, go to tools/QSO Forwarding and click the box to receive UDP broadcasts from WSJT-X. Select which log database to use. Make sure the port numbers are the same for both:
Alan
WA9WUD1 -
Thanks Alan, sounds like the best way forward, 73
Don AA5DE
- 418 Community Topics
- 717 The Flea Market
- 225 SmartSDR+
- 472 SmartSDR for Mac
- 282 SmartSDR for iOS
- 270 SmartSDR CAT
- 225 DAX
- 397 SmartSDR API
- 141 Aurora
- 1K Genius Products
- 366 Tuner Genius XL
- 139 Antenna Genius
- 333 Shack Infrastructure
- 237 Networking
- 150 Contesting
