Can SmartSDR remember gain settings by antenna?
Andrew VK5CV
Andrew VK5CV Member ✭✭
edited June 2020 in New Ideas
On the 6500 I use 2 transmit antennas as well as the RX and transverter ports for receive.
The signal levels are often quite different so I need to adjust the gain as I change the antenna selection for best S/N.
In the ANT tab or in the slice pane can a future version have gain persistence by antenna and or frequency please?
Andrew VK5CV
1 votes
Open for Comments · Last Updated
  • Patrick
    Patrick Member ✭✭✭
    edited June 2020
    I think you are limited by band, if you are talking about RX preamp gain.
  • Toffy
    Toffy Member ✭✭
    edited April 2020
    same here even withe my Maestro/Flex6600, I can only set them all to the same values. Different gain values are not possible. Too bad
    Tof DJ6ZM
