Can SmartSDR remember gain settings by antenna?
Andrew VK5CV
On the 6500 I use 2 transmit antennas as well as the RX and transverter ports for receive.
The signal levels are often quite different so I need to adjust the gain as I change the antenna selection for best S/N.
In the ANT tab or in the slice pane can a future version have gain persistence by antenna and or frequency please?
Andrew VK5CV
Andrew VK5CV
I think you are limited by band, if you are talking about RX preamp gain.0
same here even withe my Maestro/Flex6600, I can only set them all to the same values. Different gain values are not possible. Too bad
Tof DJ6ZM
- 692 The Flea Market
