Possible RF problem in Shack
Great thing about glass is, it does not allow lightning to follow it!
Exactly, and fiber is not nearly as expensive as was stated.
My situation is not RF on the feeding coaxials but rather close internet modem with 900mhz yagi a few feet from the transmit antennas.
Grounding the PC was also helpful but at the end of the day fiber works greater than you might think.
An aside I no longer worry about a lightning pulse taking out my network along with my Flex.0 -
You might ask why the modem on the tower.
I need the height to hit the access point until time civilized cable comes to my area.1 -
I add an abandon old router, using its LAN side with DHCP off as a switch, between my radio cabinet and the main router.
Congrad for DXing in area without civilized cable. Quiet station assured.0
Thanks all for your replies. They sent me to the books, the web, and the bank.
Here's what I did.
I made sure that all equipment was bonded and the bond was grounded (could not ground the computer, a mac mini. I had no screws or protrusions, so I left it alone). I have a copper pipe running behind the boxes and ran braid from the tube to the boxes. The tube is connected by braid to outside ground.
I purchased snap on ferrites in various sizes and went to town with them on coax and internet cables,
I purchased a pair of copper/fiber converters (GTECK on Amazon for 40/each) and fiber cable and ran fiber from my router directly to the flex.
I am also in the process of dressing the rabbit's nest of usb, power, ethernet, control cables behind the boxes.
So far, I am no longer seeing the lock up pattern from RF as before. I may have solved this one. Thanks all for your help.
Phil, K3UT
(The fiber was primarily for ESD protection; I live in an area of lightning strikes, power outages on the GA coast)
Phil what are the part numbers of the fiber items...? Would like to see what they are. THX Erika DD
Excellent Phil, Happy you got some resolve. Enjoy. Erica premade LC works well. It's two fibers.0
These are the converters I used. One is on top of the Flex connected with a .5m ethernet cable and the other is next to the router with a .5meter ethernet cable
https://www.amazon.com/gp/product/B06XBSZJL3/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
This is the optic cable I got.
https://www.amazon.com/gp/product/B079J6FDBG/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
Sets up in a few minutes, no programming. I now have the peace of mind that surges through the internet cable are a thing of the past.
We have Buried Power and Cable here, but it wasn't always that way. Here's the house's original power service panel from 1896 (120v DC one circuit fused Plus and Minus side) that was still feeding 1/2 of the house on AC when we got here Sept '16
... Just **** in larger fuses was SOP..
Very cool.0
Erika - Where is your home?
I spent part of my electric utility career in New York City, Consolidated Edison. At the time, ConEd was supporting portions of the old Thomas Edison DC distribution system. Some of the older NYC buildings continued to use DC for their elevators.
Later on, ConEd was paying for the old buildings to use MG sets (Rotary AC to DC converters) to replace the need for DC distribution.
Alan
WA9WUD1 -
Rock Rapids, IA. The far NW Corner of Iowa 6 miles south of Minnesota and 20 miles east of South Dakota. The utility switched over to AC in 1921 or 22... I have the book here... Everything WAS heated via coal around here back then. A deposit was found in the eastern part of the county way back when. They didn't get Natural gas here until 1955. Erika DD0
- 376 Community Topics
- 106 SmartSDR+
- 427 SmartSDR for Mac
