6600m F-Keys LED
Rick_W4UEF
Member ✭
Hi All,
My 6600M (v3.18 when it became available) has been running flawless for about a year. However, the F-KEY BUTTONS no longer have backlights.
I did the following troubleshoot:
1 - rebooted
2 - when INFO, Operated, SmartLink Setup, Log In screen popup, all BUTTONS
have backlights
3 - after enabling OPERATE, all BUTTONS backlights are still on
4 - after enabling RUN v3.18 (and after reboot), there is no F-KEY BUTTONS
Backlight. All other buttons have backlights when enable including
LOCK BUTTON
5- did a factory reset (held pwr button until it turned WHITE)
6 - did steps 2, 3, and 4 above
6 - still no F-KEY BUTTONS Backlights
Before submitting a HELP TICKET, I would like to thank your help in advance.
73 de Rick W4UEF
1 - rebooted
have backlights
LOCK BUTTON
73 de Rick W4UEF
Rick
Would you verify that when you tap on the MENU button on the Maestro display, and then select Maestro, that the Button backlight option, near the top is still enabled. That could be the problem. Also check that the LED slider is not set too low.
73, NO5J - Jay0 -
for the 6600M: Menu--Front Panel--Button Backlight Enabled???
Hi Neil,
At 77 years old, I still can't see the forest through the trees. Always just looked at the LED Bright Control to the right and never looked to the left under DISPLAY Control.
Many thanks as I can sleep better again.
73 de Rick W4UEF0 -
Hi Jay,
I got a definitive answer from Neil N3DF. On my 6600M, I never looked to the left under (FRONT PANEL MENU) DISPLAY Control to see BUTTON BACKLIGHT disabled/enabled.
Many thanks for your rapid response.
73 de Rick W4UEF
- 362 Community Topics
- 621 The Flea Market
- 8.1K Software
- 46 SmartSDR+
- 6.3K SmartSDR for Windows
- 178 SmartSDR for Maestro and M models
- 417 SmartSDR for Mac
- 268 SmartSDR for iOS
- 252 SmartSDR CAT
- 188 DAX
- 378 SmartSDR API
- 9.2K Radios and Accessories
- 27 Aurora
- 225 FLEX-8000 Signature Series
- 929 Maestro
- 904 Genius Products
- 327 Tuner Genius XL
- 118 Antenna Genius
- 289 Shack Infrastructure
- 203 Networking
- 141 Contesting
- 984 Third-Party Software
