How to configure SpotCollector to send spots to Flex
Pat N6PAT
Can someone please post the settings or screen pics of how to configure Spot Collector to send spots to the Flex?
Also, will the spots send be based on whatever filtering is currently active in Spot Collector or are all spots sent?
Pat,
There's two steps.
Click on config in the commander window. Click on the bandspread tab. Click on 'display calls on the panadapter' in the upper left hand portion of the bandspread tab.
Then go to SmartSDR and click on settings, then click on spots in the drop down menu, be sure spots are enabled.
That should do the trick.
What ever spots make it to spot collector, based on your filtering, should make it to the panadapter.
Hope that helps.
Rich - N5ZC
I got it to work but with limitations.
CW Skimmer can use all 4 IQ channels allowing Spot Collector to display 4 bands at the same time but apparently I can only display spots in SSDR for the current VFO selected in Commander.
Is this how it works or am I doing something wrong?
Does Slice Master have a limitation like this or will it display spots from CW Skimmer on all the displayed panadapters at the same time? Also, does Slice Master have the same filtering capabilities as Spot Collector (certain states, countries, etc.)?
What I'm trying to get is being able to display spots for all of the open slices and be able to filter them differently for each band0 -
I am able to see spots on open slices. Make sure you are not filtering out the band in question. It should show what ever you see in the spotcollector panel.0
I can get spots to show on 2 different slices when using the AxB function in Commander but cannot get three slices.
Spot Collector is currently showing spots for three bands 20/30/40 and I have three slices open for the bands but spots are only showing on bands that I choose for VFO A and B in Commander.
I must be doing something wrong or is it limited to only the two bands that are VFO A and B in Commander?0 -
hi all
When I click on Bandspead of the Commander, I get a band map of where the 6500 is. I do not see what you call "Display calls on the panadapter".
If I click on a spot on the band map, the rig will QSY there, but how do I get the spots to show as callsigns on the panadapter ? 'it is enabled on the Flex.
Thank youi + 73
Paul F6EXV
Step-by-step instructions are here:
https://www.dxlabsuite.com/dxlabwiki/FlexSignatureDisplayCallsigns
Thanks fo reply.
Quote part if that link :
On the *Bandspread* tab of Commander's Configuration window,
check the *Display calls on panadaptor* box in the upper-left corner of the tab
Unquote
I do not have this 'Display call on panadaptor" box. I only have some sort of logo like DX written in red letters, and in the center, I only have the choice of change (not sure what that means).
See file attached of what that window shows.
Where can I find it ?
Paul F6EXV
1. what version of Commander are you running (check the Main window's title bar)
2. in the Radio panel on the Configuration window's General tab, what Model have you selected?0 -
Hi
I am using version 14.3.1 and I have chosen SDR-6500 in the Radio choices.
Is there an errorlog.txt file in your Launcher folder? If so, please attach it to an email message, and send it to me via aa6yq@ambersoft.com
You will get faster DXLab support if you post to the DXLab Discussion Group, of which you are already a member.0 -
Resolution of this problem: Commander was not correctly configured to connect to Paul's 6500 and as a result could not determine what version of SmartSDR was running. Thus Commander did not offer the option to display the callsigns of active stations on SmartSDR's panadaptor.1
Having the same issue. Cannot get the spots to display on the Flex-6600 waterfall.
RUNNING:
Commander v 14.5.8 (on the BANDSPREAD tab i have enabled "display call on panadaptor"
In Flex Settings > Spots (is enabled)
Running SmartSDR 2.4.9
Win10 Home v1903 build 18362.592
Can you point me in the right direction?
Rob AK7RM0 -
As a first step, Rob, please follow the step-by-step instructions in
<https://www.dxlabsuite.com/dxlabwiki/FlexSignatureDisplayCallsigns>
If that doesn't get you going, let me know.0 -
Yes Sir,
I tried that before posting the comment, still no joy!
I can see the DXLabs is communicating with the 6600 because it's following the frequency just fine in the Commander window.0 -
OK. Please do the following:
1. on the General tab of Commander's Configuration window, check the "Log debugging info" box
2. terminate Commander
3. start Commander
4. wait until several new callsigns have been added to SpotCollector's Spot Database Display
5. direct SpotCollector to generate a local spot for P5DX on a frequency visible in your SmardSDR panadaptor, and wait for it to appear in the Spot Database Display
6. On the General tab of Commander's Configuration window, uncheck the "Log debugging info" box
7. attach the errorlog.txt file from your Commander folder to an email message, and send the message to me via
aa6yq (at) ambersofl.com
I can not get the spot to show on the panadaptor.. Error message: "SpotCollector is not connected to the Spot Source DX Central that you have designated to convey outgoing spots"0
Rob, please follow the 7 step procedure in my post of 1 week ago.0
- 363 Community Topics
- 624 The Flea Market
- 8.1K Software
- 69 SmartSDR+
- 420 SmartSDR for Mac
- 270 SmartSDR for iOS
- 253 SmartSDR CAT
- 188 DAX
- 379 SmartSDR API
- 31 Aurora
- 233 FLEX-8000 Signature Series
- 933 Maestro
- 909 Genius Products
- 329 Tuner Genius XL
- 120 Antenna Genius
- 291 Shack Infrastructure
- 204 Networking
- 447 Remote Operation (SmartLink)
- 771 Peripherals & Station Integration
- 989 Third-Party Software
