Slicemaster error messages with Win10Laptop, Flex 6600 trying to activate CW Skimmer
KC5LL
Member ✭
New guy here- just got a Flex 6600.
Win10 Laptop running SDR 3.1.8
Installed SDR 3.1.8, N1MM, HRD, and Slicemaster prior to 10M ARRL event.
Everything worked perfectly the whole weekend. Turned everything off (Flex and Computer)
Next day the Slicemaster would not activate CW Skimmer like it had for 3 full days perfectly.
I do not know if my Dell Precision M 4700 had a Windows update occur after the contest.
Now when I power up the shack here is my sequence:
1.) Flex computer is turned on and left alone a few minutes while it powers up.
2.) Laptop is started. Upon successful power up I activate in this order-
a.) Slicemaster (and it appears to start successfully when I observe messages at bottom)
b.) SDR 3.1.8 is started
c.) most times I start up HRD as well.
Note: on another desktop computer i have in the shack this sequence gets everything working properly.
3.) New Flex guy so I am only using one slice, set to Channel 1 on DAX
4.)When I go to the CW mode nothing happens. SDR continues to operate and the following error messages appear at the lower left hand corner of Slicemaster underneath the normal startup sequence. Here is picture- ERROR messages started at 19:40:47 in this photo
It looks like your CW Skimmer config file for slice A has been corrupted. Your guess as to how this happened would probably be better than mine.
The easiest fix would be to simply delete it and let Slice Master make a new one for you the next time you launch CW Skimmer. In your case, the offending file is located at
C:UsersDellAppDataLocalK1DBOslice-masterSlice-A
If, after you remove the file, you still have the same problem it would imply that your default config file for CW Skimmer is also corrupted. (Slice Master copies that and modifies it when it launches CW Skimmer).
--Don
3 -
I'll try that now. Thanks Don!
BOOM!!!! Works perfectly sir. I really appreciate the help Don.0
- 394 Community Topics
- 670 The Flea Market
- 177 SmartSDR+
- 453 SmartSDR for Mac
- 276 SmartSDR for iOS
- 216 DAX
- 389 SmartSDR API
- 80 Aurora
- 982 Maestro
- 954 Genius Products
- 350 Tuner Genius XL
- 130 Antenna Genius
- 312 Shack Infrastructure
- 218 Networking
- 146 Amateur Radio Interests
