FLEX 3000 software lockup
Michael W
Running PowerSDR KE9NS current version software. After a period of time the software no longer receives . I click power off then on and all is ok once again. Seems like a when no menu clicks are selected this "freeze" seems to happen. I have kept the default settings. The pc is a I7 3.3G w/32G ram quad core. The KE9NS software shows only 10% cpu usage. Any suggestions on what might be the cause? I have uninstalled and reinstalled and the 2.7 software from FLEX does NOT freeze up. So....some setting in the KE9NS software? Looking for assistance. Thank you ...Mike
which windows version?
.NET framework update?0 -
Had the same issues Mike. Switched to VER 2.8.0.80 and seems better now. Also had several other com ports running with omni rig in the back ground. Today I will re install the other com ports for SDRPLY with tracking at the same time. Just to see if it causes conflicts.
Hope this helps as I have been running the original KE9Ns software VER 2.8.0.80 with no freezes for almost a week now in daily use.
73 and God Bless.
Charles
FLEX 3000 10 yrs old
OH yeah Windows 10
WB4QBD
Thank you all for the reply. I have current updated .NET framework and windows 10. Version 2.8.0.140. I had lockup 2 times. Click START to start program and unlocks. CPU usage on my i5 desktop...25% average.
WD8BP
I've waited to reply until updating my KE9NS software to 2.8.0.141 in hopes that would fix the problem, but it didn't. I've had this issue since about ver. 2.8.0.137, perhaps earlier. The time between freezes varies widely from a few minutes to about an hour with no obvious correlation to any other software running or anything else I can see.
I love the KE9NS versions of PowerSDR and hope this can be cleared up.
Mac Mini with latest updated version of Windows 10 running under Boot Camp. The OS has been quite stable.
Tom / K3ORC0 -
I don't think the lockups are related to the PSDR version of software even as It may seem that it is. I suspect your are having split second connection dropouts causing it. Many of us are running PSDR under Win 10 without ever having a lockup. So in light of that it seems like an OS software issue.
Check your Flex firewire driver for latency events and change the driver settings accordingly.
I run my PSDR on a GETAC S400 with an i5 dual core CPU and 8GB RAM. No dropouts and no lockups.
If I try the same on my I7 VAIO 8GB RAM I get a lot of latency and sometimes a lockup. All W10pro.
All depends on the firewire chip. Should be from TI.
Latency is a killer, the best latency scanners are from the audio&MIDI guys, because audio
dropouts in a recording session are a nogo ... 73, Alex - DH2ID0 -
It looks like Alex found the source of the trouble.
I remembered that when I first set up my Flex 3000 and PowerSDR years ago, there was a latency problem, which I fixed. The fix is to change the IEEE1394 driver (find it in the Device Manager) back to the "Legacy" version.
I did that last night after discovering that a Windows update last April had reset my system to a TI driver which has excess latency. My PowerSDR has been stable since changing to the Legacy driver, with no freezes.
Microsoft has removed it from its original location, but it can still be found here:
https://download.microsoft.com/download/6/C/D/6CDAFBA0-054A-44FA-B627-BC1F1E1C6772/1394_OHCI_LegacyDriver.msi
It is listed as a driver for Windows 8.1, but it works properly on my computer with the latest updated version of Windows 10. YMMV.
-- Tom / K3ORC1 -
Tom, I left my Flex 3k running for 17 hours now with my GETAC S400, a semirugged notebook I can recommend and that you can get used on the bight for about 400
bucks here. No lockups.
Operating System:
Microsoft Windows 10 Professional Build 18363.535 (1909/November 2019 Update)
Merry Christmas, Alex - DH2ID
DPC latency checker:
Hello all. I have recently again purchased a FLEX 3000 and i am still having the freeze lockup I had few months back. I installed the 1394 OHCI_Legacy_Driver.msi but still software freezes after a period of time. I have the good graphite firewire cable. Windows 10 all drivers up to date.
Any suggestions?
Thank you
WD8BP
- 113 SmartSDR+
- 921 Genius Products
- 124 Antenna Genius
