Smartlink login fails on Windows 10 pcs
K2CB Eric Dobrowansky
I have two different pcs running the latest Win 10 with November 19 updates. Both fail to work using Smartlnk. When you click the login icon, the popup window just sits there and hangs.
I have disabled firewall protection as a test, but still no luck. My Win 7 pcs are working fine. The same Win 10 pcs work fine when used with SSDR locally to the 6xxx radios.
Any suggestions?
Eric
K2CB
Any suggestions?
Eric
K2CB
Hi Eric, I had the same issue and opened a ticket about it. After trying many things and waiting for Dan at FRS to get back to me i had a gentleman from HP Smartfriend Services look at my computer. Mostly he did a cleanup however he identified and removed iO_bit uninstaller as a bad program. He said they had many issues with it. After removing the program and finishing the reboot everthing worked again Bye the way before the Fix i could use a different laptop with a fresh install of the FRS and get thru the login.. This fixed my issue for.my HP computer. Good Luck. Ray0
Tried everything I can think of at the moment. Still no go. Here is a screenshot of where it hangs up.
That is where mine hung as well. There must be a program interfering. The gentlemans name was Anand Singh at HP smartfriend services. He cleaned my computer, removed that program i said easier and we installed McAfee livesafe. Did a cleanup and scan then rebooted. It resolved my issue. Nice guy as well. Good luck.0
This issue with Internet Explorer. Need install old updates and all ok. I have this White whindow on many Pc with win7,win100
No problem with Chrome.0
I tried setting my default browser to Chrome, Firefox, etc..... still no luck.
When I am at home and on my internal WiFi network, SSDR starts right up and the login never comes into play, but when on an external connection, it hangs up as per the photo above.
Is the Smartlink login window an actual browser pop up, or part of the SSDR code?
Eric
K2CB
Got it working. Reset the IE11 advanced settings to default, and all is good now.
Thank you, Tim, for your assistance!
Eric
K2CB
- 361 Community Topics
- 620 The Flea Market
- 8K Software
- 29 SmartSDR+
- 6.3K SmartSDR for Windows
- 415 SmartSDR for Mac
- 267 SmartSDR for iOS
- 252 SmartSDR CAT
- 188 DAX
- 378 SmartSDR API
- 9.2K Radios and Accessories
- 27 Aurora
- 222 FLEX-8000 Signature Series
- 928 Maestro
- 902 Genius Products
- 325 Tuner Genius XL
- 118 Antenna Genius
- 288 Shack Infrastructure
- 202 Networking
- 141 Contesting
- 982 Third-Party Software
