Do I have to purchase a license to use a used flex radio
Larry Deyoe
Do I have to purchase a Flex Radio license to use a used Flex Radio 6300 I just purchased from a former Flex Radio user?
Not at all. The license travels with the radio for the highest version he was licensed for. I hope that makes sense.0
Is there such a thing as a former Flex user? Larry easiest to check with the former owner to see whether he or she had V2 or V3 licence. If not, the radio will work with V1 Smart SDR.
Thanks a lot. I contacted the former owner and he told me it was version 2.4.9 I am trying to install that now on a pretty old PC. I already purchased the "Dog Park Software version for this and its been a nightmare. SO... maybe a refund there tomorrow. I can't get my PC to restart as it gets stuck on the screen saying "operations are in progressThe machine will be turned off automatically after the operations are complete." I don't want to "unplug it" to force a restart... I'm just feeling frustrated about this.
I know it will be worth it. It's just been difficult
Thanks a lot for your help. I'm so excited to have a radio this good... I just want it to work!0 -
DogparkSDR is specific for am Apple Mac.
You might want to check your "pretty old PC" against the suggested specifications to see if it will meet the minimum for SmartSDR 2.4.9 You'll find information in the Support area of the main FlexRadio website.
Per the prior owner you can run any Version 1.x and Version 2.x release of SmartSDR, but I'd start with the 2.4.9 they said they were running. The download is free from FlexRadio (links are on the main page of this forum) .
When you decide to upgrade to SmartSDR Version 3.x there is a cost.
As for your stuck PC, who knows where you sent it trying to install a Mac program on a Windows platform? If it has stayed stuck, try the Ctrl-C routine, and the Ctrl-Alt-Del one to see if you can interrupt things. If you can get Task Manager to open you may be able to **** the Dogpark install. Otherwise you probably have to pull the plug and hope for the best.
Everything you actually need to get going you can find in the Flex-6300 user manual and SmartSDR v2.x user manuals in the support area of the main FlexRadio website.
GL and 73
Steve
K9ZW
Blog: http://k9zw.wordpress.com0 -
Often when you get responses like the one you're seeing about the PC delaying while turning off it is because Windows has loaded an update and is in the middle of installing it. You may have multiple things going on. When MS decides it's time to update my PC, which has pretty good performance, normally, response time becomes very doggy and messy. I just walk away and come back later. Good luck getting this running - you will like it once it's set up!
I have aborted an installation of SmartSDR without issues. It can just be started over, and usually works the next time.
The PC doesn't need to be high end. Windows 7 laptop works here. SmartSDR can be throttled back to work with most PCs.
Thanks John! Got it working!
I wish dealing with the RFI were as easy.
As a former Flex user of a 5000A RX2-ATU-VU5K, and a 6500, welcome Larry to the elite of radios. Oh, as Brian pointed out, was never really a former user, still have a 1500 and the flagship 6700 radio.
- 636 The Flea Market
- 144 SmartSDR+
- 431 SmartSDR for Mac
- 261 SmartSDR CAT
- 200 DAX
- 46 Aurora
- 958 Maestro
- 57 FlexControl
- 932 Genius Products
- 302 Shack Infrastructure
- 141 Amateur Radio Interests
