Compact 1500 Watt Custom Built for my Flex 6400M
As promised here is start of my Amplifier built by Jim @ Dx World Jim_811@yahoo.gr This newest one with SWR Metering and Power Meter. The two board front left of picture are twin 1500 Watt transistors Custom Black Box is being built now Amp will be complete in 14 days .Ill post more pictures of built/ Joe KL4 QG
2
Man, you've got some fun lying ahead of you!
Two places that might be helpful:
SSPA Facebook Site - all sorts of doods building these amps
N4GA Website - more of a general EDU site
Enjoy!
Rob
Rob I’m not good with my hands Jim at Dx World the professional amplifier builder ,I have his first model 1500 watt , I use it at water plant when working overtime.It sounds better than my Ten Tec Titan 425 that uses two 800 Tubes , Dx World tops the Titan for wattage output too. He builds amazing amps HF,UHF and VHF Thank You Rob for kind words !!1
The finished 1500 watt amp will look like0
Pricing ? Do you have to supply your own power supply ?0
Jim can supply the 48 volt power supply or you can Buy PS it’s best email Jim email address my first post ! I don’t want Q price for Jim newest model amps with SWR and Power Meters as parts prices might changed ... Jim will give you spec on power supply’s ,the PS are all over EBay or supply houses most under $100 My first 1500 watt amp with power Supply was $1900 but remember that was a custom build for me - All my friends on AK SSB nets are giving me my best signal and audio reports they produce very clean signals on receiving Stations Scopes .0
Can you supply a url to his site, please?
http://www.dxworlde.wixsite.com/dxwor...
Tell Jim ,Joe from Alaska sent you he nice family guy he answers emails fast0 -
Joe, does your amp change bands automatically ?0
No I don’t like auto band switching I don’t trust !!!0
The metal cabin just received
I have the same amplifier. What are those 2 other metal boxes for?
It’s surprise your see soon.1
Following closely.1
Ok I’ll let the Cat out of box the two other black boxes are qrm eliminator to build0
it works with any transceiver. this connect between transceiver and amplifier.
is good if you have qrm noise from local area . It is used to reduce or eliminate qrm from receiver like noise that produce some locals tvs or power lines etc. see this video: https://youtu.be/mtoO_UJBW0c0 -
today have test the two modules separately and lpf working excellent !
Hello Joe today have make a stress test to modules.i have put 2 temp protection that if temp goes to 60*c on top case of ldmos or if temp goes 45*c on heatsink will bypass amplifier until it cool down to safe temp. i have also the swr protection and current protection board ready.will set swr to stop linear when is 2:1 or more
More progress
project so far...now the final is the back cover and will start all adjustments and tests. 73s
Hello Joe
the amplifier is ready.
working very well.
have test everything to load and antenna.
modulation very clean.
i have set the swr protection to about 1.8-2:1 and test it also with no antenna like if antenna broke!protection work excellent!
also have overload protection that if power output goes more about 1700w to stop it.
and also temperature protection that if goes very hot it bypass amplifier until cool down.
input 0-100w max
output 1-1700w max 160-10m and 1450w 6m. I also have put RCA jack on the back of amplifier for PTT start to connect with transceiver because the auto start cannot work with the protections. will send you photos of back to see it later.and nice videos Happy Holidays0 -
I’m very excited In mean time I’m using my late father Ten Tec Titan 425 amp great old boy very powerful ,going loan 425 to high school ham club when new amp gets here -
Happy Holidays All
Joe
I’m looking trying his QRM Master too Joe ,tomorrow will have ready the qrm eliminator also0
Hi Joe here is the video:
https://youtu.be/2ccLNkzxQOg 0 -
- 391 Community Topics
- 664 The Flea Market
- 441 SmartSDR for Mac
- 206 DAX
- 61 Aurora
- 974 Maestro
- 949 Genius Products
- 348 Tuner Genius XL
- 128 Antenna Genius
- 308 Shack Infrastructure
- 216 Networking
- 145 Amateur Radio Interests
https://youtu.be/VXQ6TTwiaCc
