V2.6.1. upgrade showing multiple Client Notices, immediate launch of SSDR, and SmartLink visibility
Mike Krzystyniak
Greetings:
I just updated my FLEX6700 to 2.6.1 from 2.4.9 and now I noticed three separate client connections windows pop up, versus only the one previously. I know changes were made but is this the expected norm now?
Also, when I launch SSDR, it launches without pausing, where before I had the connection option screen and the SmartLink settings/connection option. Is this an install goober or is it also the new norm? If the latter how does one select an alternate Radio, or get to Smartlink connection and setup?
Thank You...
73 Mike K9MK
Thank You...
73 Mike K9MK
Hi Mike,
The selections when it came up the first time defaulted to "Connect to the last radio" the wording might be different but the point is made. No radio selection because you connected to your radio. That is deselectable...
The three connections are another couple settings, they are start DAX and CAT with SDR... So you end up with three ICONS in your taskbar, SDR a DAX and a CAT. Each are three separate modules needing configuration.
Once SSDR is open go to the settings option on your SDR menu and the number two setting is Chose Radio / Smartlink setup. :-)
Enjoy, Erika DD
Thank you Erika,
I didn't notice the option as it shot by me during install. Sure enough it was that settings option, and indeed that was it.
On the Client messages, I get one message now for each module (SSDR, DAX, CAT) where before I only saw only notice. That change in visual notifications just caught me thinking I had multiple instances of the same module. Not an issue as everything seems to work fine,
Many thanks.
73 Mike K9MK
That's great, glad I could help. Have fun with your radio! 73, Erika DD
- 113 SmartSDR+
- 922 Genius Products
- 124 Antenna Genius
