FlexControl stopped
Frank W2YK
FlexControl stopped working. I assume my PC (Win10) auto updated overnight, since all my open programs were gone this morning. SmartSDR no longer recognizes FlexControl.
Where to look? I assume the USB drivers are messed up...
I am surprised unplugging the Flex control and plugging it back in does not reset the USB settings.
didn't work... tried several USB ports, restarted the PC. the 3 lights/legends on the Control are on...0
Go into devices and check what port it's on and that it is not sharing that port with anything else. If it is just move it to another unused port.
After a number of reboots and using different USB ports on the PC, ran SmartSDR once and FlexControl worked... now I can't get SmartSDR to connect to the 6400 again. Keep getting "Unable to get to the radio" messages. Maestro works fine... time for some playing around and then start a new issue thread.
Frank,
It's a network issue, make sure that the radio and computer are on the same IP subnet. Try remove the DC from the radio and back up, if still fails, how do you have the radio and computer connected to your network??
Dudley
Hi Dudley,
All is OK now. I did 2 things at once, uninstalled all previous versions of SmartSDR then reinstalled current version. then, as you suggested, cut DC to the 6400 and restarted it.
Thanks, now for CQWW CW this weekend...
Frank
- 349 Community Topics
- 613 The Flea Market
- 7.9K Software
- 5 SmartSDR+
- 6.3K SmartSDR for Windows
- 411 SmartSDR for Mac
- 267 SmartSDR for iOS
- 249 SmartSDR CAT
- 186 DAX
- 375 SmartSDR API
- 9.2K Radios and Accessories
- 22 Aurora
- 205 FLEX-8000 Signature Series
- 920 Maestro
- 892 Genius Products
- 454 Power Genius XL Amplifier
- 322 Tuner Genius XL
- 116 Antenna Genius
- 283 Shack Infrastructure
- 199 Networking
- 137 Contesting
- 754 Peripherals & Station Integration
- 973 Third-Party Software
