FlexControl stopped
Frank W2YK
Frank W2YK Member
edited August 2020 in FlexControl
FlexControl stopped working.  I assume my PC (Win10) auto updated overnight, since all my open programs were gone this morning.  SmartSDR  no longer recognizes FlexControl.
Where to look?  I assume the USB drivers are messed up...
  • Bill -VA3WTB
    Bill -VA3WTB Member ✭✭✭
    edited March 2020
    I am surprised unplugging the  Flex control and plugging it back in does not reset the USB settings.
  • Frank W2YK
    Frank W2YK Member
    edited November 2019
    didn't work...  tried several USB ports, restarted the PC.  the 3 lights/legends on the Control are on...
  • Bill -VA3WTB
    Go into devices and check what port it's on and that it is not sharing that port with anything else. If it is just move it to another unused port.
  • Frank W2YK
    Frank W2YK Member
    After a number of reboots and using different USB ports on the PC, ran SmartSDR once and FlexControl worked...  now I can't get SmartSDR to connect to the 6400 again.  Keep getting "Unable to get to the radio" messages.  Maestro works fine...  time for some playing around and then start a new issue thread.
  • Dudley  WA5QPZ
    Dudley WA5QPZ Member ✭✭✭
    Frank,
    It's a network issue,   make sure that the radio and computer are on the same IP subnet.    Try remove the DC from the radio and back up,  if still fails,  how do you have the radio and computer connected to your network??
    Dudley
  • Frank W2YK
    Frank W2YK Member
    Hi Dudley,
    All is OK now.  I did 2 things at once, uninstalled all previous versions of SmartSDR then reinstalled current version.  then, as you suggested,  cut DC to the 6400 and restarted it.
    Thanks, now for CQWW CW this weekend...
    Frank
