In SS SSB...Audio Problems with N1mm
Richard Zalewski
Not getting audio monitor in headset. Only speaker.
Long delays after using Fkeys (N1MM)
Same problem as Mitch and Grant. Headset is fixed but the delays can only be cured by turning radio off and then on again.0
Richard,
Setup here is a 6700/Maestro. Used N1MMLogger+ audio the entire contest with no issues. Don't forget the computer in the setup. I am using a Win7 machine, AMD X4 955 3.2 GHz, 8.00 Gig RAM 64 bit OS. Delays such as you describe make me think external computer issues.
My headphones are plugged into the Flex (Not an issue with the 6600M as you don't have the Maestro/6600 choice far as I know).. Tx DAX on, Microphone DAX on, Monitor on and set to comfortable volume. N1MM setup per instructions.
Does that help?
John0 -
There is a software bug with using monitor with DAX and VOX. I reported this issue to Flex support. This is a software bug that will be addressed in the future. This issue has been logged as defect number: G76911
Did not work for me either. Some random combination of VOX operating PTT or something else, maybe at the same time as DAX stream was active would sometimes kick-in the monitor audio for the next over before you lost it again. This did work properly in previous releases. It's a PITA no knowing for certain how your voice keyer sounds in a contest.0
Flex claims this defect was introduced after the 2.4.9 code release. I have not rolled back and will wait for the fix.0
- 361 Community Topics
- 622 The Flea Market
- 8.1K Software
- 47 SmartSDR+
- 6.3K SmartSDR for Windows
- 179 SmartSDR for Maestro and M models
- 417 SmartSDR for Mac
- 269 SmartSDR for iOS
- 252 SmartSDR CAT
- 188 DAX
- 378 SmartSDR API
- 9.2K Radios and Accessories
- 27 Aurora
- 226 FLEX-8000 Signature Series
- 929 Maestro
- 904 Genius Products
- 327 Tuner Genius XL
- 118 Antenna Genius
- 289 Shack Infrastructure
- 203 Networking
- 141 Contesting
- 985 Third-Party Software
