In SS SSB...Audio Problems with N1mm
Richard Zalewski
Richard Zalewski Member ✭✭
Not getting audio monitor in headset.  Only speaker.
Long delays after using Fkeys (N1MM)
  • Richard Zalewski
    edited November 2019
    Same problem as Mitch and Grant.  Headset is fixed but the delays can only be cured by turning radio off and then on again.
  • John Kludt
    John Kludt Member ✭✭
    edited May 2020
    Richard,
    Setup here is a 6700/Maestro.  Used N1MMLogger+ audio the entire contest with no issues.  Don't forget the computer in the setup.  I am using a Win7 machine, AMD X4 955 3.2 GHz, 8.00 Gig RAM 64 bit OS.  Delays such as you describe make me think external computer issues.
    My headphones are plugged into the Flex (Not an issue with the 6600M as you don't have the Maestro/6600 choice far as I know)..  Tx DAX on, Microphone DAX on, Monitor on and set to comfortable volume.  N1MM setup per instructions.
    Does that help?
    John
  • Joe N3HEE
    Joe N3HEE Member ✭✭
    There is a software bug with using monitor with DAX and VOX.  I reported this issue to Flex support.  This is a software bug that will be addressed in the future. This issue has been logged as defect number: G7691
  • Steve G1XOW
    Steve G1XOW Member ✭✭
    Did not work for me either. Some random combination of VOX operating PTT or something else, maybe at the same time as DAX stream was active would sometimes kick-in the monitor audio for the next over before you lost it again. This did work properly in previous releases. It's a PITA no knowing for certain how your voice keyer sounds in a contest.
  • Joe N3HEE
    Joe N3HEE Member ✭✭
    Flex claims this defect was introduced after the 2.4.9 code release.  I have not rolled back and will wait for the fix.
