Why Does My Flex 6600M All of a Sudden Think it is a Maesto?
Al Dewey
I had some external power supply problems today. My Astron Power Supply would shut down when I increased the 6600m output to about 30 watts which, of course, shut down the 6600M also. During one of the restarts, I got a message on my 6600M saying that the Flex did not shut down properly. I replaced the Astron Power Supply and all seems to work fine now at full power but, for some reason, my 6600M is identifying itself as a Maesto instead of a Flex 6600M. The word "Maesto" shows up in the 6600M front panel under MENU. When I connect to "Maesto" with CAT, all seems to work fine with CAT. However, it is unsettling that my 6600M thinks it is a Maesto.
By the way, I do not have (or have ever had) a Maesto. How can I change the name of my 6600M back to what it really is? The 6600M will not let me change the Station Name on the "Front Panel" screen.
Al, K0AD
Al, K0AD
I think a FULL Rest should return everything back to normal..0
Yes, I expect it will but thought I would see if there is an easier fix before doing a full reset.
A factory reset is very easy and only takes a few moments..save your profiles though.
Seems there are a lot of gender changes anymore HI HI
I had various 6400M problems when using my Astron supply with the Flex. Changed to a switching supply and all problems went away.0
I replaced my Astron with a little Alinco DM-330MV switching supply which is working great. As for the original problem, I did do a factory reset and my 6600M still identified itself as a Maestro. However, after the reset, I was able to Front Panel display and change the station name back to FLEX-6600M. I was not able to do that for the reset. As for the bad Astron supply, I listed it on our local reflector for free saying that it was bad and all kind of people jumped all over it even wanting to pay me for it.0
Astron support is awesome - Call them. I was using a 30A version of their linear power supply and upgraded to a 50A with all my additional 12V needs. 30A was working fine - Just ran a little warm.
- 378 Community Topics
- 119 SmartSDR+
- 193 DAX
- 38 Aurora
- 258 FLEX-8000 Signature Series
- 947 Maestro
- 924 Genius Products
