Using my I phone Hot Spot, Would Not Work??
Robert Lonn
So I updated all my 6600M, and Laptop computer to 2.6.1 software for Windows. I then validated at home that I could log into my Flex Radio and everything acted normal.. I have done this in the past and everything acted normal.. A few months ago I also took my laptop windows 10 machine to work and used a WiFi connection from a persons cable modem. Everything acted normal.
Again everything normal, but when I went out to the local astronomy site, I was unable to gain access to the Clubs WiFi network, so I figured I would use my iPhone 8S as a Hot Spot. However the screen kept saying that no radio was found..
Being on Verizon network I asked my friend who was on T-Mobile to turn on his hot spot and the same result.. I was able to Log Off and Log Back in but again no radio found... Wife validated my 6600M was turned on and working normally..
In doing a search on Flex Site while out at the site, Yes Internet Connectivity was working fine with the iPhone as a hot spot, I found where folks could not log into the iPhone Hot Spot, but I could do that, just no radios found when opening up SSDR for Windows... Not sure what I might do to get things working???
UPDATE: I asked my neighbor if I could gain access to his GUEST WiFi network to try something and he said OK, once I logged into his network and validated Internet Access, I opened up SSDR and got the same No Radio Found???? I then changed my WIFi hotspot that the Flex is plugged Into, over to his Guest network and then everything was good again.. So as long as my Laptop and the Flex are both on the same network, all is good, but when on separate networks is stops working??
Robert
WA6PHN
Robert
WA6PHN
Have you confirmed that Smart Link is working on the Radio correctly and the IP ports are being passed through your Router (Green Light) on the SmartLink display?
Once you have the Green light in config process) then, Log out on Smartlink and Re-login (where you have to hit the local PTT or CW key) which registers the Radio on SmartLink.
I just had to do mine here
Then you may get it to show up using your Phone as a hot spot if your Provider doesn't block it.
Hope this helps.
Bret
I can not even get to the Smart Link display, it comes up with No Radio Found??? It only works when I am on the same Home Network.. I know it worked once, 8 months ago, with my iPhone as a hot spot, but not anymore.. This is a screen shot of my computer. It is on my neighbors Guest Network. BTW, clicking on Smart Link Setup does nothing.. Lower Right settings are normal.. It allows me to Log In, give it my email and password and that works OK..
Let me add one more detail. My Flex radio is plugged into a WiFi extender along with my ICOM IC-9700 , ICOM IC-R8600 and GeoChron 4K World Clock. And all of those work normal.. The WIFi extender is then connected to my Home WiFi router and that is connected to the cable modem..
UPDATE!!! I went into the Flex 6600M menu and I was SHOCKED when it said I was not registered for SmartLink??? Being able to use my Laptop on my home network must be DIFFERENT then using SmartLink on a different network??? In any case using my neighbors Guest WiFi, this time everything worked as it should?? Not sure where along the way I became Un-Registered with SmartLink??? Could this be related to doing a software upgrade, it requires you to re-register???
And I went back to my iPhone and it is now working with my iPhone Hot Spot!! So all good news but my question is I did register the radio last year, wonder if doing software upgrades require you to re-register each time... When I switched from my neighbors Guest WiFi to my iPhone, Smart SDR required me to Log Back In again, that makes sense to me..
RSL0 -
It must dump the registration sometimes When running on your home network the same one your radio is on your NOT using smart link Glad that was it Bret0
OK, that explains why it worked OK on my Home Network! I guess when it is on a remote network, SmartLink must register with the server in Dallas TX, but not the same functionality when on a home networking... Hard to explain in an email but I understand the difference now..
So now I am running a Data Test with my iPhone. Letting it run for 30 minutes, then I am going on the Verizon web site and look at my data Usage to figure out how much I will use per Hour.. I have 4 Gig of Data, probably need to not watch so many NFL games on my phone!! LOL...
Thanks Brent..0
- 393 Community Topics
- 668 The Flea Market
- 174 SmartSDR+
- 450 SmartSDR for Mac
- 276 SmartSDR for iOS
- 266 SmartSDR CAT
- 215 DAX
- 389 SmartSDR API
- 70 Aurora
- 981 Maestro
- 952 Genius Products
- 349 Tuner Genius XL
- 129 Antenna Genius
- 311 Shack Infrastructure
- 217 Networking
- 146 Amateur Radio Interests
