Comparing a local and remote antenna with Smart SDR?
Andy - KU7T
Hi,
I would like to use SmartSDR in combination with SmartLink to compare 2 80 m antennas. One is local, on is at another ham. Both radios are 6600s. Again, this is mostly for antenna testing (and not for contesting, as this would be against the rules).
I know I can connect via SmartLink. However, is there a way to listen to both signals at the same time (left ear location 1, right ear location 2)? Or can I launch two instances of SmartSDR on the same radio?
Andy
KU7T
Andy
KU7T
Andy,
I don't know of a way to do this with a single computer/SSDR instance.
It would be easy with a second computer setup with SSDR. But I feel you might have big latency differences so listening to them at the exact same time might yield strange results.0 -
Hi Andy
You can run 2 copies of SmartSDR at the same time, but they have to be different versions. So, for your test, you might have to downgrade 1 radio while you run the test.
Mike0
- 376 Community Topics
- 106 SmartSDR+
- 427 SmartSDR for Mac
