CW Skimmer
N2TTA
N2TTA Member ✭✭
edited November 2019 in FLEX-6000 Signature Series
Hello
im trying setup CWskimmer, but signal did not decoding
any idea?
Yuri N2TTA
  • W2ECK
    W2ECK Member ✭✭
    edited October 2019
    Yuri - I have a 6600 and use the Slicemaster program, I have never had CWSkimmer work so well for me - Slicemaster does all the interface setup for you. It's available at https://github.com/K1DBO/slice-master-6000. Has a very good help file for installing.
    73 Paul w2eck
  • AH0U
    AH0U Member
    edited October 2019
    Me too.. SliceMaster works like a charm and even a know nothing like me had it working first time easy
  • Craig_KØCF
    Craig_KØCF Member ✭✭✭
    edited October 2019
    The signals in the passband of Skimmer are NOT CW signals. They appear to be FT8. Tune the radio so that CW signals appear in the Skimmer window and it will likely work.
  • N2TTA
    N2TTA Member ✭✭
    edited October 2019
    Paul,
    i though Slicemaster help connect slice with third party programs. But if i connect one slice directly to skimmer, signal should decode anyways
  • N2TTA
    N2TTA Member ✭✭
    edited October 2019
    Graig, it is CW. when switch Signal I/O device to DAX audio RX1 it decoding some signal in narrow bandwidth
  • John - AI4FR
    John - AI4FR Member ✭✭
    edited October 2019
    I agree with Craig above. I briefly tried CWskimmer and found that the frequency it reported was not accurate and it bounced all over the place. I never did find a solution except for when I used slicemaster to open it. After that all went well.
  • N2TTA
    N2TTA Member ✭✭
    edited October 2019
    will try tonight again, thank you!
  • N2TTA
    N2TTA Member ✭✭
    edited October 2019
    Restart PC, and all works. Thanks
