CW Skimmer
N2TTA
Hello
im trying setup CWskimmer, but signal did not decoding
any idea?
Yuri N2TTA
any idea?
Yuri N2TTA
Yuri - I have a 6600 and use the Slicemaster program, I have never had CWSkimmer work so well for me - Slicemaster does all the interface setup for you. It's available at https://github.com/K1DBO/slice-master-6000. Has a very good help file for installing.
73 Paul w2eck1 -
Me too.. SliceMaster works like a charm and even a know nothing like me had it working first time easy0
The signals in the passband of Skimmer are NOT CW signals. They appear to be FT8. Tune the radio so that CW signals appear in the Skimmer window and it will likely work.
Paul,
i though Slicemaster help connect slice with third party programs. But if i connect one slice directly to skimmer, signal should decode anyways0 -
Graig, it is CW. when switch Signal I/O device to DAX audio RX1 it decoding some signal in narrow bandwidth
I agree with Craig above. I briefly tried CWskimmer and found that the frequency it reported was not accurate and it bounced all over the place. I never did find a solution except for when I used slicemaster to open it. After that all went well.
will try tonight again, thank you!0
Restart PC, and all works. Thanks0
- 383 Community Topics
- 638 The Flea Market
- 144 SmartSDR+
- 434 SmartSDR for Mac
- 273 SmartSDR for iOS
- 261 SmartSDR CAT
- 200 DAX
- 275 FLEX-8000 Signature Series
- 958 Maestro
- 57 FlexControl
- 934 Genius Products
- 342 Tuner Genius XL
- 303 Shack Infrastructure
- 141 Amateur Radio Interests
