How to work CW thru PC and SSDR
Thanks.
Aloha,
Pat - KH6KL
If you're in the shack with the radio, connect to the radio. Otherwise, I think you have to use CWX.
Yeah there’s a key jack in the back of the Flex 6400 (page 21 of the Hardware Reference Manual). The radio also has an internal keyer.
Brian KB1VBF0 -
I also wish to remote operate my Flex6400 with physical morse key, not CWX.
AFAIK, this is not supported yet.0 -
The problem is that while remote you need local sidetone. You can hook up a paddle remotely and get local sidetone several ways - buy a Maestro, buy a pair of RemoteRig boxes, buy a pair of Winkeyers1
“CW sidetone” Thread has some more info. I use just one Winker at remote site as detailed later on down in the thread. Works FB.1
Take a look at the "Remote Keyer Interface" solution for -free- remote CW operation, with a keyer (or straight key) interfaced to the PC through a very simple interface to a Serial Port.... https://groups.io/g/RemoteKeyerInterface.
Side-Tone at your remote operating site can come from your PC or from the keyer. No Maestro required.
Mark - AD7EF
Thanks Mark.
Just downloaded, soldered an USB-CWkey adapter using an abandon firmware download cable.
I don't have Winkeyer yet. It works well with straight key connected to the RS232 CTS pin, without WinKeyer.
( At first glance, I spend some time to figure out why the download link doesn't work - must join the group first to download ;)
Rocky BL7iB
- 388 Community Topics
- 156 SmartSDR+
- 53 Aurora
- 970 Maestro
- 944 Genius Products
