KE9NS software
Stephen Emlyn-Jones
It has previously been suggested that the KE9NS software is ideal for the Flex 1500.
However the web address given is unavailable due to an unsupported protocol.
Can anyone offer any suggestions. Thanks.
Steve GW4BKG
Steve GW4BKG
https://ke9ns.com/flexpage.html
I just tried it here and the download was fine. Hope this helps. I had a 1500 and have used this package.
Pat
this is message I get :-
This site can’t provide a secure connectionke9ns.com uses an unsupported protocol.
ERR_SSL_VERSION_OR_CIPHER_MISMATCH
I am using the Chrome browser but had the same result with MS Edge
Steve0 -
It is a problem with your browser, can you use firefox or something eles?
just tried Firefox and had the same problem.
I will try some other browsers.
Steve0 -
I tryed this link without any problems. To confirm.
Try rebooting your computer? and trying0 -
I just tried it and ke9ns.com is alive and well.0
Stephen,
I just tried his site also with FireFox and Chrome, both worked.. Maybe either your antivirus is blocking it or you have cookies blocked. Try resetting your cookies in the browsers, then maybe checking your antivirus.. Check it out on another computer too, Just a couple of thoughts.
Dudley
WA5QPZ
Do a search on the "ERR_SSL_VERSION_OR_CIPHER_MISMATCH" error, as it usually is a local (end user) machine problem. There lots of articles and some videos showing the various fixes.
Steve
K9ZW
Blog: http://k9zw.wordpress.com0 -
thanks for the various suggestions. I have tried some options suggested by a Google search but still no success. I am giving up for the moment but may revisit later on.
Steve
GW4BKG0 -
The problem appears to you used https://ke9ns.com/flexpage.html the browser is expecting a secure connect. The KE9NS site is not responding to secure connections, at least for me. https will Soon be require standard and is assumed by most newer browsers. The none secure link works. http://ke9ns.com/flexpage.html 73.. Ken - VE5KC0
Check again today, the problem is fixed. The KE9NS site is now responding to secure connections. 73.. Ken - VE5KC0
My original post was concerning access to the site of KE9NS. I am glad to advise that I have now been able to download the software. I used a VPN as for some reason my ISP was blocking the site !
I have been able to install the software and get it working with my Flex 1500 but have a question concerning the other items which have installed at the same time.
Apart from the main package version 2.8.0 I also have Power SDR Data transfer which seems obvious but in addition a FlexRadio exe which does not seem to do much and also a "PowerSDR_database_RevQ_F1.5K_0514-3268_28-04-2020_14.40" which has appeared as an xml document.
Can somebody advise the function/operation of these other items.
Thanks.
Steve
GW4BKG0
- 376 Community Topics
- 106 SmartSDR+
- 427 SmartSDR for Mac
