KE9NS software
It has previously been suggested that the KE9NS software is ideal for the Flex 1500.
However the web address given is unavailable due to an unsupported protocol.
Can anyone offer any suggestions. Thanks.
Steve GW4BKG
  • Pat Hamp
    Pat Hamp Member ✭✭
    edited October 2019
    https://ke9ns.com/flexpage.html
    I just tried it here and the download was fine. Hope this helps. I had a 1500 and  have used this package.
    Pat
  • Stephen Emlyn-Jones
    edited October 2019
    this is message I get :-
    This site can’t provide a secure connection
    ke9ns.com uses an unsupported protocol.
    ERR_SSL_VERSION_OR_CIPHER_MISMATCH
    I am using the Chrome browser but had the same result with MS Edge
    Steve
  • Bill -VA3WTB
    Bill -VA3WTB Member ✭✭✭
    edited October 2019
    It is a problem with your browser, can you use firefox or something eles?
    edited October 2019
    just tried Firefox and had the same problem.
    I will try some other browsers.
    Steve
  • Bill -VA3WTB
    edited October 2019
    I tryed this link without any problems. To confirm.
    Try rebooting your computer? and trying
  • Bob G   W1GLV
    Bob G W1GLV Member ✭✭
    edited June 2020
    I just  tried it and ke9ns.com is alive and well.
  • Dudley  WA5QPZ
    Dudley WA5QPZ Member ✭✭✭
    edited March 2020
    Stephen,
    I just tried his site also with FireFox and Chrome,  both worked..   Maybe either your antivirus is blocking it or you have cookies blocked.   Try resetting your cookies in the browsers,  then maybe checking your antivirus..   Check it out on another computer too,     Just a couple of thoughts.
    Dudley
    WA5QPZ
  • Steve K9ZW
    Steve K9ZW Member ✭✭✭
    edited April 2020
    Do a search on the "ERR_SSL_VERSION_OR_CIPHER_MISMATCH" error, as it usually is a local (end user) machine problem.  There lots of articles and some videos showing the various fixes.
    Steve
    K9ZW
    Blog:  http://k9zw.wordpress.com
    edited October 2019
    thanks for the various suggestions. I have tried some options suggested by a Google search but still no success. I am giving up for the moment but may revisit later on.
    Steve
    GW4BKG
  • Ken - VE5KC
    Ken - VE5KC Member ✭✭
    edited October 2019
    The problem appears to you used https://ke9ns.com/flexpage.html the browser is expecting a secure connect. The KE9NS site is not responding to secure connections, at least for me. https will Soon be require standard and is assumed by most newer browsers. The none secure link works. http://ke9ns.com/flexpage.html 73.. Ken - VE5KC
  • Ken - VE5KC
    edited October 2019
    Check again today, the problem is fixed. The KE9NS site is now responding to secure connections. 73.. Ken - VE5KC
    edited April 2020
    My original post was concerning access to the site of KE9NS. I am glad to advise that I have now been able to download the software. I used a VPN as for some reason my ISP was blocking the site !
    I have been able to install the software and get it working with my Flex 1500 but have a question concerning the other items which have installed at the same time.
    Apart from the main package version 2.8.0 I also have Power SDR Data transfer which seems obvious but in addition a FlexRadio exe which does not seem to do much and  also a "PowerSDR_database_RevQ_F1.5K_0514-3268_28-04-2020_14.40" which has appeared as an xml document.
    Can somebody advise the function/operation of these other items.
    Thanks.
    Steve
    GW4BKG
