Low budget amplifier to use with Flex 6300
Santiago Mejia HI8O
After 4 month using a Flex I would like to keep up adding to it.
I’m looking for recommendations on a low budget amp to use with my 6300, that I can control thru PC and use remotely. I’m not able by far to meet PGXL and/or 2k amps nor most 1k for that matter, yet.Any recommendations? I could settle for something between 600w to 1kw.
73 de Santiago, HI8SMX
I recommend the Elecraft KPA-500. There is lots of documentation available about using it with the Flex radios.2
Check out the Gemini HF-1K
It’s a solid state linear amp with auto band switching together with computer control. I am very happy with mine but check out the reviews on eham. A really neat feature is support of the 630M band through to 6m band.
I have an ALS-600 from Ameritron. They also sell a cable the provides auto band switching between the amp and my FLEX 6400. It works very well.3
If I can offer my opinion, STAY AWAY from the low budget AMPs it will cost you less in the long run to go with a great amp like the Elecraft KPA-500 or PGXL. There are used KPA-500's every now and again and can be controlled by the F6300.
Check with the reviews before you buy sometimes they get it right.
73's
Bret
WX7Y
There are sometimes great deals to be had on used SPE Expert 1K-FA amplifiers. The 1K-FA has been replaced by newer models, so used 1K-FA's can be obtained at very affordable prices these days. I use one. Flawless and foolproof operation with Flex radios!
You owe it to yourself to check the reviews on this amp as part of your research.
I agree with Bret. Save, look for an purchase a quality amp. The KPA-500 is a great amp but only 500w which is like a single S-unit at best in rough conditions. Although this sometimes is all you need.
I stretched and purchased an SPE 2K FA. I will probably own this amp the rest of my life. It works wonderfully well and loafs along at my typical 500 to 1000w.
Mark WS7M1 -
Santiago,
Not sure what your budget is, but an ACOM 600S will work fine with the 6300 (I use one here), and you can use software from here: https://www.m0yom.co.uk/download/acom-director-plus-0-6-0-beta/ to control it.
I used the instructions found here: https://morsetutor.com/2016/12/flex-6500-usb-serial-to-acom-600s/ to build an interface cable for the ACOM 600S to the 6300.
FYI - I am selling my ACOM 600S along with the required interface cables for the 6300 for US$2000 plus shipping.
73, Tony K4QE1 -
Best **** for buck $$
250-15000 watt Solid State Amps
1 have 1500 watt model easily does 1500 watts
Getting better audio reports with DX World Electronics
Than with my Ten Tec Titan 425 tube amp
Facebook page under DX World Electronics
Tell them Joe C KL4QG sent you from Bethel Alaska
He great family guy ,good at answering any and all questions -Hand Made Amps
I’m getting second 1500 watt for water plant in Bethel AK
They cover 10/160 and Mars Bands /6 meters
with SWR meter and Power Meter (The newest models) Im using the amp on 6400M1 -
Lots of suggestions, but what is your definition of "low budget"?
You´re right. I´m unable to go over US$2,000 for the time being. Specially considering the exchange rate of my local currency.0
Thanks a lot everybody for your recommendations and advices, certainly a lot to research and review. Will keep you posted on the matter.
Really appreciate it.
73, Santiago, HI8SMX0 -
Not commenting on value (low cost, reliability, etc), but something to consider. Going from 100 watts to 400 watts is 6 dB, approximately 1 S-unit increase in signal strength. Going from 100 watts to 1000 watts is 10 db, a little over 1.5 S-units increase in signal strength.
If the situation permits, improving the antenna system can bring much more gain. And it works both ways, receiving and transmitting.
An amplifier is kinda like 4 wheel drive, It helps you to go, but it doesn't help you stop.
**** but it’s sure a lot fun watching my DX World amp hitting 1500 watts plus on my bird watt meter.
Joe
KL4QG Agree about antennas I raised my Dipole from 25 feet 65 feet wow what difference than add 1500 Watts - Who hears me I hear them now//0 -
Where can I write you with a question?0
conover1956@gmail.com0
I’m getting lots emails on DX World Amps
Here Jims email just check the time in Greece
jim_811@yahoo.gr
Thanks all for interest Jim got 2 year old girl and nice wife they both starting out in life
1500 Watt =1700 Euro /$1900 USA
My amp does 1700 watts plus on dummy load all bands and
I set at 1400-1500 watts for AK SSB nets never misses beat running very cool the two fans -no noise none /
It’s plug and play for my 6400M1 -
I have had the 1K-Fa together with my 6700 since I bought it 2 years ago. Perfect match, works great. Running 4-500 Watts on RTTY and digital is no problem. SSB i would say 7-800 watts during Run in contest is no problem.
Experts own software for this amp is old, never updated (I belive) and useless. But works great with Mini Console for Flex.
Mini Console together with LP-100 and DDUtil, works great to handle everything via a PC screen or remote with Team Viewer.
Another discussion on Mini Console
https://community.flexradio.com/flexradio/topics/frstack-ver3-and-spe-amp?topic-reply-list%5Bsettings%5D%5Bfilter_by%5D=all&topic-reply-list%5Bsettings%5D%5Breply_id%5D=20231431#reply_20231431
Thanks Johan! very interesting.0
You might find it easy stateside to hook up your spe amp,but it’s a nitemare in the Uk as it’s impossible to get the connection leads here0
Another option- if you want to build or an assembled unit are the EB104 amps- https://eb104.ru/karta-sayta/directory.
I must confess that I´m not a lot into DIY, but I´ll take a look at it. Thanks.0
I having second DX World Electronics 1500 watt amp being built this one has power Supply on outside It’s also has new SWR and Power Meters Jim sends me and others pictures and videos as he builds your — Amp so you can follow along as he building it/ it’s cool watch your amp bring built -At $1900 US dollars for $1500 watts it’s great buy/ Joe KL4QG DX World Amps Here Jims email just check the time in Greece jim_811@yahoo.gr0
Yes, I spoke with Jim several times and we are evaluating some questions. He´s very quick to respond and answers to all questions.
Here nice little jewel 500 watts plus best best I seen for 500-600 watt amp
He has a video testing into Bird Watt meter all his Testing has been spot on and videos0
- 246 Community Topics
- 488 The Flea Market
- 7.3K Software
- 328 SmartSDR for Mac
- 241 SmartSDR for iOS
- 224 SmartSDR CAT
- 161 DAX
- 343 SmartSDR API
- 8.5K Radios and Accessories
- 768 Maestro
- 42 FlexControl
- 726 Genius Products
- 251 Tuner Genius XL
- 84 Antenna Genius
- 223 Shack Infrastructure
- 150 Networking
- 118 Contesting
- 116 Amateur Radio Interests
- 810 Third-Party Software
