microphone bias not working
Stan VA7NF
Member ✭✭✭
6700 V3.1.8 using rear balanced input with XLR or phono input does not supply the microphone bias. Mic and XLR cables work fine with my own preamp supplying the bias. I have measured voltages between all XLR leads with no change between BIAS ON or OFF
What is the mic? Make sure there isn’t a blocking cap in the circuit.0
From the Flex-6000 Hardware Manual:
"7.10.2 MIC vs. LINE Use
The balanced input can be used as a microphone level or a line level audio input. The microphone level is suitable for a dynamic microphone. The balanced input does not have any DC bias capability. If your microphone requires bias power (5VDC) or phantom power (48VDC), an external power supply is required."
If you want to use an electret microphone, you have to use the front-panel mic connector, or as noted above, use an external bias source.
Thanks Craig for the reference. Perhaps twice a year I use a mic and this year it was Scouting Jamboree on the air. I was sure that over the past 5 years I have used a balanced mic requiring phantom power, perhaps old age was the problem.
Brian - The mic is a Behringer C-1 which works very well when passed through a "tube" preamp. Previous mics that have worked were a Blue Yeti and most often a Sennheiser headset which I know does NOT need phantom power.
Thanks.0 -
Stan Can you measure with a multimeter to see if there is voltage on the mic connector? Mike.0
Mike,
Original note - Measured the voltages on all leads, as Craig referenced, there is no phantom voltage on the balanced XLR rear port. Disappointing as a high percentage of XLR mics use phantom power and BIAS set on was just expected to apply to the BAL port.0 -
Hi Stan
My fault, sorry, I missed that and I should have known better. Even worse, I actually knew that.
Thanks for calling me out on it.
- 371 Community Topics
- 94 SmartSDR+
- 424 SmartSDR for Mac
- 270 SmartSDR for iOS
- 937 Maestro
- 54 FlexControl
- 996 Third-Party Software
