HRD keep displaying "Error opening DAX Audio RX 1 (FlexRadio System)" after I start DM780
Carl Walthall
I'm running V3 3.1.8 and the latest version of HRD. I'm getting the messages "Error opening DAX Audio RX 1 (FlexRadio System) Soundcard I/O: Failed at 48kHz and 8kHz, giving up"
13:12:58 Soundcard I/O: Opening DAX Audio RX 1 (FlexRadio Syste (device ID 11)
13:12:58 Soundcard I/O: Sample rate ...: 48kHz
13:12:58 Soundcard I/O: Buffer size ...: 24576
13:12:58 Soundcard I/O: Oversampling ..: On
13:12:59 Soundcard I/O: Error opening DAX Audio RX 1 (FlexRadio Syste ID 11 at 48kHz -
13:12:59 Soundcard I/O: Error code 1 - Incorrect function.
13:12:59 Soundcard I/O: Failed at 48kHz, retrying at 8kHz
13:12:59 Soundcard I/O: Sample rate ...: 8kHz
13:12:59 Soundcard I/O: Buffer size ...: 4096
13:12:59 Soundcard I/O: Oversampling ..: Off
13:12:59 Soundcard I/O: Error opening DAX Audio RX 1 (FlexRadio Syste ID 11 at 8kHz -
13:12:59 Soundcard I/O: Failed at 8kHz, giving up
I also tried WSJT-X and get the message "Error in Sound Input, An error opening the audio input device has occurred". I have SDR Slice-A set to DAX channel 1 an digital mode selected. The DAX control panel shows "RX Streams, Slice A is Streaming".
I'm running WIN 10 64Bits OS, I was able to run both programs before up grading to V3 3.1.8. I read the community postings and made sure I have output device connected to my computer.
I sure I must be over looking something?
73's Carl N8CDW
73's Carl N8CDW
Hi, for HRD try to configure your computer's audio system. Forget DAX ... no longer needed. Same thing with WSJT-X.
Good luck and let them know
73 Mauro0
- 391 Community Topics
- 664 The Flea Market
- 441 SmartSDR for Mac
- 206 DAX
- 59 Aurora
- 974 Maestro
- 948 Genius Products
- 348 Tuner Genius XL
- 127 Antenna Genius
- 308 Shack Infrastructure
- 216 Networking
