HRD keep displaying "Error opening DAX Audio RX 1 (FlexRadio System)" after I start DM780
Carl Walthall
Carl Walthall Member ✭✭
edited October 2019 in SmartSDR for Windows
I'm running V3 3.1.8 and the latest version of HRD. I'm getting the messages "Error opening DAX Audio RX 1 (FlexRadio System)  Soundcard I/O: Failed at 48kHz and 8kHz, giving up"
13:12:58 Soundcard I/O: Opening DAX Audio RX 1 (FlexRadio Syste (device ID 11)
13:12:58 Soundcard I/O: Sample rate ...: 48kHz
13:12:58 Soundcard I/O: Buffer size ...: 24576
13:12:58 Soundcard I/O: Oversampling ..: On
13:12:59 Soundcard I/O: Error opening DAX Audio RX 1 (FlexRadio Syste ID 11 at 48kHz -
13:12:59 Soundcard I/O: Error code 1 - Incorrect function.
13:12:59 Soundcard I/O: Failed at 48kHz, retrying at 8kHz
13:12:59 Soundcard I/O: Sample rate ...: 8kHz
13:12:59 Soundcard I/O: Buffer size ...: 4096
13:12:59 Soundcard I/O: Oversampling ..: Off
13:12:59 Soundcard I/O: Error opening DAX Audio RX 1 (FlexRadio Syste ID 11 at 8kHz -
13:12:59 Soundcard I/O: Failed at 8kHz, giving up
I also tried WSJT-X and get the message "Error in Sound Input, An error opening the audio input device has occurred". I have SDR Slice-A set to DAX channel 1 an digital mode selected. The DAX control panel shows "RX Streams, Slice A is Streaming".
I'm running WIN 10 64Bits OS, I was able to run both programs before up grading to V3 3.1.8. I read the community postings and made sure I have output device connected to my computer.
I sure I must be over looking something?
73's Carl N8CDW
  • Mauro HB9FBG
    Mauro HB9FBG Member ✭✭
    edited October 2019
    Hi, for HRD try to configure your computer's audio system. Forget DAX ... no longer needed. Same thing with WSJT-X.
    Good luck and let them know
    73 Mauro
