Maestro - No Tune Output
Alan
Member ✭✭✭✭
Running SDR 3.1.7 on a Maestro and PC Smart SDR.
Not sure when this started, so I cannot pin it on 3.1.7 with any confidence. On the Maestro, when I push the "Tune" button" I do not get any indication of output. I do see the TX indications both on the Maestro and on the PC SDR. Tuning works ok on the PC SDR.
No issues using "MOX" from the Maestro. Only "Tune" does not have an RF output.
I tried the usual rebooting, and just running the Maestro by itself....same problem.
What am I missing?
Here is the Maestro with the "Tuning" button depressed. Note the absence of Po and SWR indications although there is "MOX" and TX indicated.
Here is a screenshot of FRStack on the PC, with the Maestro selected. Note the "meter" indications, PA and FWD are bland and SWR is 1.0 while the Maestro is in "Tune".
Maestro TX Menu Settings:
And, TX Band Settings
What am I missing?
I seem to recall this came up a couple of weeks ago. Something about the CW sidetone being set to 100Hz. Set that up around 600Hz or 800Hz and try again.
Thanks. Problem solved.
I recall seeing those posts but since I do not do CW much, I just went by them. Never made the connection to the "Tuning" function. I now see it makes sense.
Alan0
- 394 Community Topics
- 670 The Flea Market
- 177 SmartSDR+
- 453 SmartSDR for Mac
- 276 SmartSDR for iOS
- 216 DAX
- 389 SmartSDR API
- 80 Aurora
- 982 Maestro
- 954 Genius Products
- 350 Tuner Genius XL
- 130 Antenna Genius
- 312 Shack Infrastructure
- 218 Networking
- 146 Amateur Radio Interests
