Transmit Profiles!!
Dwayne_AB6A
I have a new 1K Linear Amp which I am very proud of but concerned I don't do anything bad to damage it. Transmit profiles are awesome and the ability to switch between an AMP profile that enables the RCA TX1 Port and dials down tune and rf power and a NO AMP profile that disables the RCA TX1 port and dials up the default power. Thank you!
I definitely agree that having separate "Transmit Profiles" is very important in protecting the newer LDMOS amps.
I typically run my RF 2K+ Amp with 5W input through a 13dB pad for full legal output.
With the recent FRS upgrade to V3, I see that the "Select Transmit Profile" that appears when using SSDR is now limited to a maximum of 13 profiles.
I have also noticed that the "Transmit Band Settings" doesn't always come up as originally saved.
Sometimes, just changing to a different band will restore it to the originally saved settings; But not always, sometimes a new band change is required.
Just my observations.
Tom W3FRG
- 394 Community Topics
- 670 The Flea Market
- 177 SmartSDR+
- 453 SmartSDR for Mac
- 276 SmartSDR for iOS
- 216 DAX
- 389 SmartSDR API
- 80 Aurora
- 982 Maestro
- 954 Genius Products
- 350 Tuner Genius XL
- 130 Antenna Genius
- 312 Shack Infrastructure
- 218 Networking
- 146 Amateur Radio Interests
