ARRL Frequency Measurement Test - Nov 8 0200 Z (that is Thursday Night ET)
Mike-VA3MW
edited October 2019 in New Ideas
Hey all
If you have never tried it, the ARRL Frequency Measurement Test is on the evening of November 7th, Thursday night.     http://fmt.arrl.org/
It would be awesome to have a whole bunch of Flexers submit their measurements.
Years ago, I was able to do sub-hertz measurements with nothing more than a 6300 and using the FreqCal part of WSJTx.  https://www.physics.princeton.edu/pulsar/K1JT/wsjtx-doc/wsjtx-main-2.0.1.html
If you have a GPSDO or a 10Mhz reference OSC, you have an amazing piece of test equipment and should have no issue reporting less than 1hz of the exact frequency.  The procedure is well discussed here:  https://community.flexradio.com/flexradio/topics/arrl-fmt-tonight-getting-the-most-accurate-frequency
Now is the time to practice on WWV and some AM Broadcast stations and ask questions about how to make it work.
This is the schedule.
0200Z-0520Z Nov 8, Submit Measurements by 0200Z, Nov 11
K5CM 40m (near 7064 kHz)
0200Z Call up for 3 minutes
0203Z Key down for 2 minutes
0205Z End of run
K5CM 80m (near 3598 kHz)
0215Z Call up for 3 minutes
0218Z Key down for 2 minutes
0220Z End of run
0500Z Call up for 3 minutes
0503Z Key down for 2 minutes
0505Z End of run
0515Z Call up for 3 minutes
0518Z Key down for 2 minutes
0520Z End of FMT
1 votes
In Review · Last Updated
  • Logan KE7AZ
    Logan KE7AZ Member ✭✭
    edited October 2019
    Spectrum Lab is also a good tool. It can record lots of data for subsequent analysis. Plus you can run multiple instances with multiple slices. It does require some setup so practice early. Logan, KE7AZ
    edited October 2019
    Logan
    Do you have any basic steps that someone could follow who might want to try to use Spectrum Lab and what data they would record?
    Would it be as simple to record the carrier with a 1khz offset so that at a later point, you can measure the tone?
  • Logan KE7AZ
    edited October 2019
    Here is a link to an excellent presentation that shows how to setup
    Spectrum Lab and Flidigi.  It has step by step screenshots that show
    exactly what fields need to be addressed.
    www.ve2azx.net/technical/FreqCal.pdf
    Regarding your question, Spectrum Lab has a data export function in the File menu
            File->Export calculated data (continually)
    This feature creates a text file of data that you have selected from the full spectrum. Unlike Flidigi, Spectrum Lab does not delete the export file when changes are made, it just appends to the existing file.
    The text file can be loaded into Excel and the "text to column" function used to put the data into columns. The data is delimited by blanks.  From here you can do your analysis.
    When you click this item, it brings up a screen that allows you specify what is contained in each column of a text file.
    Here is a screenshot of an export file format that I have used.
    <img alt="" title="Image 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
  • Logan KE7AZ
    edited October 2019
    My response got truncated...  Here is the rest, hopefully.
    This setup captures the strongest frequencies of a WWV signal: the carrier, 100Hz tone and the 500Hz tone.  The Flex is tuned to 10.000.000.  It also captures two test signals at 10.000.505 and 10.000.510.
    For the FMT, I plan to put a slice/Spectrum Lab pair at each of the FMT frequencies minus 100 Hz.  That would put the nominal carrier at 100 Hz in the spectrum with the actual test signal, nearby.  WWV is a good signal to experiment with.
    Good Luck with the FMT
    Logan, KE7AZ
    edited October 2019
    Today, I was playing around and I can now see that my radio is only, wait for it:
    R1|0|-19.073486,-9.536743
    That is 19 milliHertz off frequency
    I think I can live with that.
    I am using an external 10Mhz frequency reference.
    Now, to start practising with WSJTx and Spectrum Lab.
