SSDR/flex 6400 and SDRUNO/sdrplay1A same PC
IK8HCG
having available two antennas I wanted to test the two SSDR and SDRUNO software with my both radio SDRPLA1A and my Flex 6400 on the same PC, to realize my processor speed.
Well as soon as I opened the two programs I realized that sdruno managed the vfo and the ssdr band change and vice versa.
someone has the opportunity to test if he has the two software available with the relative sdr?
tnx in advance, lou
tnx in advance, lou
I am not sure that I understand your question, but I use SDR Console rather than SDRUNO with my SDRPlay. I can simultaneously run SSDR and SDR Console on the same computer. SDR Console has a feather called External Radio that will allow you to synchronize one VFO on your flex with the SDRPlay so that when you change frequency on one, the other follows.
Michael -- KM6LHD0 -
I have two sdr turned on my pc (flex6400 and Rsp1a) with two different software (ssdr and sdruno) when i running both and i use sdruno vfo or the band channel the ssdr follow what i m doing with sdruno and viceversa.0
Is that what you want it to do? You can set up SSDR and SDRUNO so that they do not follow each other if you want.
Absolutly not. May u teach me? Tnx0
Having two antenna i would run different mode and band, so two slices with my 6400 and one different receiver with my rsp1a with his appropriate software.0
OK. In SDRUNO there are two settings that control whether the SDRPlay tracks the SSDR frequency. Both are in the RX Settings. To get there, go to the SDRuno RX Control window and click on SETT. This will open the RX Settings window.
In the RX Settings window there are a number of tabs: AGC, OUT, SAM/HP RDS, CAT, ORIG, MISC and CAL.
Choose the CAT tab and uncheck the "Enable & Connect" and "RX Mode CTRL" boxes. Then go to the ORIG tab and uncheck all the boxes.
That should stop SDRuno from tracking SSDR.
Great. Now all works how i want. Send me invoice to pay.
- 376 Community Topics
- 107 SmartSDR+
- 427 SmartSDR for Mac
- 918 Genius Products
- 295 Shack Infrastructure
- 207 Networking
