6400M Using VOX keying Amplifier
KL4QG
My new solid state Amplifier keys by Carrier and Voice /VOX keying And special setting I need do on my 6400M Joe
Make and model of Amplifier would help.0
Any input0
Thank u0
Is there a link to the manual? I would like to look at it. Or is this a one of with only RF keying?
If it is unique, I would discuss with the builder and what his expectations might be.
If there is no PTT lead to the amp, then there is no settings in the radio that you can use. It will be truly plug and play.
Mike1 -
Just RF keying
No manual0 -
I updated my comments above, however, there is nothing that you can adjust since there is no PTT lead.
When you have a PTT connection, that allows you to put the Amp into TX before the radio sends RF to the Amp. Since it is RF sensing, then the Amp is now getting RF and then Hot Switching into TX.
I'm not sure why he didn't include a PTT lead since it isn't very complicated. Doing it the way he did it is much more complicated.
Let us know how it goes.
730 -
I ran Tokyo High Amp years with RF sensing to Icom 718 no problems - I think today a lot people over think about a problem that not a problem just not a normal way / I like input here please He sells lots amps with no user complains0
Just just plug and play0
Hi Joe
Nothing much to add. There is nothing you can adjust other than drive power.
I would be curious to see if it drops the first part of a CW transmission of a bit of the audio in digital mode operation.
Does he publish the time it takes to go into tx?
Mike0 -
I just emailed him about I’m curious to see if it drops the first part of a CW transmission of a bit of the audio in digital mode operation. Does he publish the time it takes to go into Tx Do you want his email address too? Joe0
His answer
Joe it go to tx in millisecond it doesn't lose letter and it has millisecond delay off.
all my amps works with same auto ptt no one ever told me that loses anything CW or Digital. Joe -this is a video from older 500w uses the same tx auto ptt just now your board it has a little more delay off https://youtu.be/6KHwu0aiIzs0 -
Good stuff... Let us know how it works for you.1
Will have two weeks
My Ten Tec Titan old and I live in Eskimo Village I’m
Just Tiered tubes Titan great amp
It’s very very good price for 1500 plus watts0 -
When I get amplifier I’ll take lots pictures inside &
Out comes with as built also drawing with pictures
Joe0 -
Amp being sent out to me next week about 14 days I should have on air Anyone wants see how amp works I’ll update here Have nice weekend0
- 391 Community Topics
- 665 The Flea Market
- 167 SmartSDR+
- 446 SmartSDR for Mac
- 208 DAX
- 387 SmartSDR API
- 65 Aurora
- 307 FLEX-8000 Signature Series
- 978 Maestro
- 868 FLEX Series (Legacy) Radios
- 951 Genius Products
- 348 Tuner Genius XL
- 129 Antenna Genius
- 309 Shack Infrastructure
- 216 Networking
- 828 Peripherals & Station Integration
- 145 Amateur Radio Interests
