FLEX 6400 FIRST FLEX MY COMPUTER IS HUCKED TO MY ROUTER DO I PLUG THE 6400 INTO THE ROUTER AS WELL ?
Charles Wallace
FLEX AND THE ROUTER MY COMPUTER IS PLUGED INTO THE ROUTER FOR INTERTNET DO I JUST PLUG THE 64OO INTO THE ROUTER AS WELL ?
Correct. Mack W4AX Alpha Team0
Charles, Mack is correct. I have found good reason to add a Ethernet switch on the router then connect your computer, radio, and any other associated devices to the switch. This has several benefits. First the data passes directly between your computer and radio with 1 or 2 mseconds of latency. Second if your router drops out or reboots your radio will not get dropped from your computer. This architecture was recommended by tech support when I was trying to reduce latency issues. My laptop running WiFi still communicates through the router to the Ethernet switch just fine for local remote. 73 Bill W9JJB0
- 389 Community Topics
- 53 Aurora
- 971 Maestro
- 945 Genius Products
- 307 Shack Infrastructure
