Heil Mic
W7NIK
I have a Heil Pro Set head set with the AD1-i and ICM Icom Microphone, for Icom radios .
The Flex mic is Yaesu pin out .
Could I wire the 8 pin plugs to match the Flex pin out ?
Will the ICM mic sound ok for a flex radio ?
Yes and yes. I have used a Heil mike on my Flex 6500 since day one. Play around with the tx equalisation to get the sound that you like best out of your Heil mike, then set that as one of your transmit profiles so each time you use it, you don't have to reinvent the wheel, just engage that profile.
I bought the MFJ-1263 Mic/ radio switch and toggle between my Heil Pro 7 and my Inrad mic. No need to rewire your mics as all done with jumper internally.0
I thought the ICM heil desk top mic requires voltage to work ? So if I wire it for Yaesu will the 6300 provide voltage to the ICM mic? The heil pro set headset I ordered the AD-y for the maestro . Thank you for the help .0
It will work fine, I have used the ICM on my Flex with no problems once your rewire the mic plug.
In the main settings menu, radio menu, Phone/CW, turn off +20DB and enable BIAS.
Use the mike equalization for best sound.0 -
It will work FB for the Maestro.
What I did for mine was avoid the adapters altogether, and put the Maestro stereo plugs on the Heil Headset.0
- 637 The Flea Market
- 144 SmartSDR+
- 432 SmartSDR for Mac
- 261 SmartSDR CAT
- 200 DAX
- 958 Maestro
- 57 FlexControl
- 932 Genius Products
- 302 Shack Infrastructure
- 141 Amateur Radio Interests
