Steppiir
W7NIK
W7NIK Member ✭✭
edited December 2019 in FLEX-6000 Signature Series
I am new to flex , I have. 6300 with sda100 controller. I have read some stuff on this web site . I am not sure where I connect this sda100? Looks like I have make a lot of different cables , I am guessing the db9 connector on the back of the radio ?
  • Mack
    Mack Member ✭✭✭
    Nick,
    The connector on the back of the radio is an HD DB-15 not DB-9. Do not ever connect a peripheral there.
    I run three SteppIR controllers. Please download the USB Configuration Guide and look at the example there. https://www.flexradio.com/downloads/usb-cable-interface-guide-pdf/
    You can very easily build your own interface cable if you have basic soldering skills.
    Here is the cable wiring diagram:
    Several cautions:
    1. You must use the top DB-9 connector on the SDA-100 (it says data out). No, I'm not making a mistake it is data out.
    2. You must use a genuine FTDI chipset in the USB to DB-9 connector that plugs into the USB port on the back of your radio.
    3. On the SDA-100 set the radio type to Kenwood, 19,200, 8, N, 1
    4. Configure the USB Settings in SmartSDR or Maestro to set the cable as shown in the USB guide.
    5. Make sure Autotrack is ENABLED using the button on the front panel of your SDA-100.
    That's it. Pretty simple. Ask questions if you get stuck.
    Mack
    W4AX
    Alpha Team
    edited September 2019
    Thanks Mac
    The document that describes how to connect devices directly to the radio can be found here:
    Not only can the Steppir be connected, so can many other devices, all at the same time.
    Mike va3mw
  • W7NIK
    W7NIK Member ✭✭
    Wow !!! Unbelievable support, grateful for the response
  • W7NIK
    W7NIK Member ✭✭
    The USB / db9 Ftdi is the only style I should? . I have older one that did show up in smart sdr software . I also have wavenode sensors for RF power , can this be added to the usb on the back of the radio ?
  • Mack
    Mack Member ✭✭✭
    Yes, the USB to serial cable must use an FTDI chip. No, the Flex cannot read PowerNode sensors. A radio can only output frequency, band, PTT type data for USB.
  • W7NIK
    W7NIK Member ✭✭
    I have a  Startech Ftdi cable , recognized by the 6300 , I  checked the pin out
    I have followed the instructions .
    I cannot get to work. Do I need the antenna connected.? Works when I do  manual .
    I get the flashing tuning.
    I loaded the drivers on my computer the startech  was updated. I plugged it in the back of the 6300 and I do not know  what USB port it is . My smartCAT has only one port. com 1
    I even tried  DDUtil going through the 6300 usb port still not able to connect
    Still not working
    My usb log
    06:14:32 (TX): IF000141344000100+0000000000020000000;
    06:14:34 (RX): IF;
    06:14:34 (TX): IF000141344000100+0000000000020000000;
    06:14:35 (RX): IF;
    06:14:35 (TX): IF000141344000100+0000000000020000000;
    06:14:36 (RX): IF;
    06:14:36 (TX): IF000141344000100+0000000000020000000;
    06:14:37 (RX): IF;
    06:14:37 (TX): IF000141344000100+0000000000020000000;
    06:14:38 (RX): IF;
    06:14:38 (TX): IF000141344000100+0000000000020000000;
