tx1/tx2 always closed
marco rinaldi
hey all
today I turned on my flex6700 and it looks like both ports rca Tx1 and tx2 are always closed (TX), didn't touched anything.
Tx3 works fine as usual, I've tried to go through menus (tx band setting & co), but no way, only the tx3 rca works proprely allowing me to operate with ext amplifier.
Any tips?
Any tips?
Hi Marco
Can you tell me what devices (amplifier?) you had hooked up to TX1 and TX2 when it was working?
You may want to reset the radio.
Export your profiles to your PC.
Reset the radio:- Press and hold the OK button while pressing and releasing the Power button.
- Release the OK button once the power LED turns white and allow the radio to continue booting normally.
If it still fails, then you will need to open up a support ticket. If it works, let us know and import the profiles you have saved.
hey Mike.
I literally flipped out today with this story...
At the end I had the idea to test the ports with an hometer and they were all ok, so checked the cable and there was a resistance on it probably a "false contact" but it was not shortcutted.
Changed the cable and all ok.
What really confused me was the fact it was ok on tx3RCA therefore I didn't suspected any hw issue, But it was....
Thks for coming back
IK2LFF Marco.
Hi Marco!
That is good news and good work with the Ohm meter. You can solve a lot of problems with one!
73 es gl de va3mw
- 632 The Flea Market
- 126 SmartSDR+
- 195 DAX
- 40 Aurora
- 955 Maestro
- 927 Genius Products
- 338 Tuner Genius XL
