Command line switch for DAX and CAT?
Gary NC3Z
Member ✭✭✭
SSDR allows you to use the "--serial=nnnn-nnnn-nnnn-nnnn" command line switch to start a specific radio automatically. Is there such a command line argument that will let CAT and DAX connect to specific radio without having to use the drop down selections in CAT and DAX?
The --serial parameter is supported however for V3.1.7 there is no way to select station name from the command line currently. So if the last station name is not appropriate then you will have to manually select the new station name. I have submitted an enhancement request with FRS via the Alpha Group.0
Thanks for the info Mark, it would have been nice with MultiFlex when you have a M model.0
- 391 Community Topics
- 664 The Flea Market
- 441 SmartSDR for Mac
- 206 DAX
- 59 Aurora
- 974 Maestro
- 948 Genius Products
- 348 Tuner Genius XL
- 127 Antenna Genius
- 308 Shack Infrastructure
- 216 Networking
