Command line switch for DAX and CAT?
Gary NC3Z
Gary NC3Z ✭✭✭
edited September 2019 in SmartSDR for Windows
SSDR allows you to use the "--serial=nnnn-nnnn-nnnn-nnnn" command line switch to start a specific radio automatically. Is there such a command line argument that will let CAT and DAX connect to specific radio without having to use the drop down selections in CAT and DAX?
  • Mark_W3II
    Mark_W3II ✭✭✭
    The --serial parameter is supported however for V3.1.7 there is no way to select station name from the command line currently. So if the last station name is not appropriate then you will have to manually select the new station name. I have submitted an enhancement request with FRS via the Alpha Group.
  • Gary NC3Z
    Gary NC3Z ✭✭✭
    Thanks for the info Mark, it would have been nice with MultiFlex when you have a M model.
