Pwr Supply Spike
Andy W3LI
When I first got my 6400M I would turn the 35 Amp power supply off after turning the Flex off. I noticed that when I turned the power supply ON a spike would light up the front panel light for just a millisecond ??? That bothered me so now I leave the supply ON and just shut the Flex OFF. However, there is a voltage on the control circuits with in the radio.
I am thinking about putting a contactor in series with the leads and key that separately maybe with a slight time delay.
Any ideas or problems that you folks have would be appreciated.
I built a low current 12 volt DC power supply to FLOAT the voltage, Diode Isolated, so no feedback.. Now when I turn off my Main 35 Amp DC power supply the float voltage will keep the radio in Standby mode.. NOTE!!! Flex states that this FLASH you see will NOT harm the radio,, but I occasionally will see the radio fail to boot up correctly when you **** the DC power to the radio... Keep in mind that when you **** your power supply it will Bleed Off for a second or so,, but powering it on is instantaneous 12 volts.. You do get the FLASH as I call it of the front panel lights..
Robert1 -
Float voltage is a great idea. The control circuits are hot and ready to work.
Tnx, Andy...W3LI0 -
By any chance did you measure the current on the line with the radio off. I have some 12 vdc @ 500ma wall warts. Maybe????0
No I did not,,, I used a 1.5 amp wall wart that was used to power a Netgear WiFi hub.. The standby voltage has to be very low,, but I never measured it???1
Tnx Robert.0
Hi Andy, I always turn off my Flex Radio before turning off the power supply. Never have an issue of any type. The only other item using the 12V pwr supply is my Palstar HF Auto Tuner. I always turn off any connected item before turning off the12 V supply.2
My Flex 6700 has the GPSDO installed. With the radio plugged in to my supply, my inline Powerwerx meter shows a current of 0.17A.2
Thank you Harry and Mark.0
Does the indicator light flash in response to inrush current from the primary input. Usually the inrush current is in response to the main filter caps on the DC side doing there initial charge up. This is assuming that you are using an analog PS. If the indicator is an OVP indicator then it could be over voltage spike triggering the OVP circuits.0
Hi PAT, not sure what indicator light your are referring to. This is a very fast spike that is just enough to flash the panel lights. Yes, the caps have to charge and there is a delay until the regulator clamps,
No OVP indicator. Flex says not to be concerned. May try the idea of a float voltage.
TNX for your comments.0 -
I guess I interpreted the panel light flash as being the PS IT’s self. Thanks for your reply.1
I thank u for being here.
That is normal and not an issue. It is not a power spike and isn't a problem that needs to be worried about.
Have you measured a spike coming from the power supply?
M1 -
No longer have a scope fast enough to catch it.0
- 633 The Flea Market
- 131 SmartSDR+
- 197 DAX
- 42 Aurora
- 955 Maestro
