SMARTSDR has lost connection to the radio. Please reconnect
Renner PY7RP
I have been using my Flex 6500 over smartlink smoothly and suddenly i lost my connection and got the error message "SmartSDR has lost connection to the radio. Please reconnect". The radio disapear from "Currently available radios" list on SSDR, CAT nor DAX. I remotely reboot the 6500 and again it becomes available as a currently available radio. When i try to connect via smartlink again.... that error message pop ups again "SmartSDR has lost connection to the radio. Please reconnect"... Does anyone have any idea on what is going on?!. PS: I did not make any recent update...
Sounds like your router "burped." I would remove the power from your radio, reboot the router, repower the radio, reboot the radio and see if it reconnects to your LAN.0 -
I had the same problem when my Flex6400M and PC (on the same LAN) were connected to the same Ethernet switch which, in turn, was connected to the router through its own Ethernet cable. As a part of my RFI reduction effort I got rid of all Ethernet switches and (almost) all Ethernet cabling. Now my PC is connected to the router though WiFi and my Flex6400M is connected to that PC with a 12" cable. LAN connection is very solid now - always five green bars.
BTW, I also abandoned my AC power modem based LAN. Instead I am using Google WiFI mesh. Three units are more than enough to cover 1800sq. ft house.
I hope that helps.
Anatoly NC6M
I gonna try to reset my remote router! TNX0
Hello Anatoly, In my case everything is connected through cables to the router.0
Check several things....
1) Double check your cables, and your connection indicators on the radio and switch or router. Do they all have the flashing light?
2) You may need to "Cold Boot" your radio in order to restore the connection between the radio and the router. (Turn off the radio, remove ALL power from the radio for about 30 seconds, then restor power and turn on the radio.) Your radio's ethernet port may not have gotten a DHCP address from your router when something was disconnected.
Ken Wells - NM9P
Unfortunately reboot did not solve the problem...
Unfortunately that did happen in my remote shack (100km from me)... Once i get there, probably in 10 days, i will try to do that. Untill there... NO RADIO for 10 days... Seems i will loose C21, T6, 6O on low bands...
I am really upset with my Flexradio experience. :.
Thank you!
Renner - PY7RP
Just to make it clear:
The radio does not list as available only AFTER i try a smarlink connection to it.
Once i try to connect to it, i get the error message "SmartSDR has lost connection to the radio. Please reconnect" AND it disappears from available list.
After the error message i tried to turn the radio OFF and ON remotely THAN it happen to show in the list AGAIN BUT never stablish a smartlink connection.
At my remote radio site i configured the radio in the LAN with a static local IP and reserved the local IP with the radio´s MAC address. Sure, i forwarded the ports from external connections (i dont remember them now) to the local ip:ports.
I already reboot the remote router but it remains the same problem.
This setup has been running OK remotely since i first installed (so i do not think it is a configuration issue at the remote router).
Actually this is the 2nd time in 2 months i get the connection unavailable... In the 1st issue (i just do not know what happened) i remade all the router configuration (with the same prior configuration) and all worked fine again... That was strange... i did not make any change on the configuration BUT just remade all that and all worked again.
i will try to configure it in DHCP mode... i will give it a try too.
NM9P's suggestion number (2) above was followed when I had the same problem as described above.
Problem solved. What bothers me is that I do not know why this anomaly happens now and then for no reason I can detect.
My call NK7B1
Are you using AVAST security software? If so, access the firewall settings page and check that the Private network is selected.
- 379 Community Topics
- 119 SmartSDR+
- 193 DAX
- 38 Aurora
- 947 Maestro
- 924 Genius Products
