preserving values using FlexLib doesn't seem to work as previously
I've noticed that, using my third party app, some values don't seem to be preserved, where they were before. The values are the AGC and AGC Value, and perhaps others. They are only preserved for the current band. I have noticed this most recently using FlexLib V2.5.1.
For example, if I set the AGC to Fast on 40 meters, and then go to 30 meters and set it to fast again, when I again connect to the radio, the AGC is still Fast on 30 meters, but Medium on 40. Is there perhaps something I'm not doing as regards the global profile, or something to that effect?
Jim,
Is it possible that you updated to v2.5+ and then downgraded? This can cause a problem with the database in the radio that can lead to the kind of issues you are describing. The solution is to do a factory reset if you ever downgrade to a version prior to v2.5 (after downgrading). Give that a try and let us know if you continue to have trouble.0 -
I have upgraded to 3.0, and then downgraded to 2.5.1, but have done a few resets since.0 -
Going between v2.5.1+ and later versions should be a problem. It is only downgrading to a version prior to v2.5 that would cause what I was concerned about.0
I have always wondered if I really understood persistence and profiles.Here's how my app currently behaves.
- Connect to the radio.
- Wait for the Status to be In_Use.
- If my profile, JJRadioDefault, is in ProfileGlobalList and ProfileTXList,
Set both ProfileGlobalSelection and ProfileTXSelection to JJRadioDefault.
Wait a while until all panadapters are created, and the pan and slice counts are equal and an even number.
If this all works, success.Note I don't currently support multiple users. IsGUI is always true.
Then upon program exit I use SaveGlobalProfile("JJRadioDefault").
- 398 Community Topics
- 678 The Flea Market
- 191 SmartSDR+
- 392 SmartSDR API
- 91 Aurora
- 988 Maestro
- 962 Genius Products
- 352 Tuner Genius XL
- 317 Shack Infrastructure
- 222 Networking
