Version 3.1.7 installed perfectly.
Brian_W9HLQ
Following the update to test, I cranked up FT8 and worked Maritania, Kuwait and Bulgaria. easy-peasy. DAX, and COM all working. The best part was that Microsoft had a big update pending. So without fear I proceeded with the update and re-boot. No problem. Thanks for removing the fear of installing OS updates.
Same with 2.6.0. Had 2.5.1 installed on to an 1809 version of windows and forced and update to 1903, then I installed 2.6.0. No DAX or CAT problems. Works as advertised. What a welcome relief to have that damnable problem resolved. Thank you Flex!
Jim, K6QE
I have never been able to get WSJT-X working. since I purchased the rig over a year ago It's pretty ridiculous. First I could receive with no transmit power, now, after the 2.6.0 update, I can transmit perfectly but I get DAX errors including installation issue or disabled sound device. I've uninstalled and reinstalled numerous times. I am a very technical guy, but super frustrated about the unbelievable amount of time I've spent on this thing. All Windows updates are current. For the first time in a year I can finally transmit, but DAX will not connect to WSJT. Any IDeas?0
- 391 Community Topics
- 665 The Flea Market
- 171 SmartSDR+
- 446 SmartSDR for Mac
- 266 SmartSDR CAT
- 209 DAX
- 387 SmartSDR API
- 66 Aurora
- 309 FLEX-8000 Signature Series
- 979 Maestro
- 951 Genius Products
- 348 Tuner Genius XL
- 129 Antenna Genius
- 310 Shack Infrastructure
- 217 Networking
- 829 Peripherals & Station Integration
- 145 Amateur Radio Interests
