FRStack Version 3.1.5.19 - SteppIR feature, UDP Radio Info feature, FDX protect
HRDLog gets it's info through a server, like MiniDeluxe.
https://github.com/krisp/MiniDeluxe/releases
DDUtil has also some HRD server functionality.
RigControl is by SmartSDR.0 -
MiniDeluxe will only work with one VFO. The current version of DDUTil has a bug in that if you are working split and VFO B is populated in the HRD logbook, if you then go back to one VFO, the VFO B field in HRD logbook is not cleared. You have to shutdown DDUTil and reopen to clear the VFO B field.0
Not only that but HRD programmers changed code between main program and Logbook. Both Mini Deluxe and DDUtil do not track radio mode in automatic Logbook entry window. This has been a cat and mouse game with HTD for years0
I am not a HRD user so I am not exactly sure what you are looking for. FRStack does have a UDP feature that sends Freq + Mode for all Slices. Most logbooks can be configured to listen for this UDP data. Have you tried that? Feel free to reach out via my email you can find in FRStack Help or QRZ to have a more in depth conversation.1
thank Max-- I can't see how I missed the "options" choice on the view menu, but I did. Old age here I guess. 73
Mark, love this upgrade and the addition of Stream Deck. Is there a way you can change the color of a selection once selected. What I'm driving at is I've incorporated a couple of buttons to Record and Playback audio from the Flex. The way it stands right now is I don't know if the Record button is on or off.0
Thanks for the feedback Alex. I will test again. I have stopped using HRD Logbook.
Try this. In the cluster of HRD Logbook click on a DX spot and see if the mode in the ALE window updates automatically. It did not for me (about 4 builds back of HRD.)
The Stream Deck software does let you set the text color. The Stream Deck plugin I wrote does not have a color change by value feature at this time.0
Mark, I cant seem to update my FRstack 3.1.5.20. App update doesnt seem to work for me, so I downloaded from your website and still wont update. Not sure why
Update- I think it has updated but splash screen still says 3.1.5.20. I tried the split and close commands and they worked, so Im guessing it did update to the new version0 -
FRStack is internally still at 1.3.5.20, but if you look at the program itself,
it shows 1.3.7.20. Just a small bug, easily corrected.
Thanks for catching this, I released a version bump to 3.1.7.21 to correct.2
Thanks0
Thanks, Mark. Great program, helps a lot!0
I got the SteppIR working today. Took a different setup than the Flex 6600/Steppir cable but have both working. I have a BigIR vertical so some of the functions do not work and had to add the 3/4 - 1/4 wave mode. What is Antenna state? Is that for the Yagi's only? And what about SteppIR Ant Freq? That value just jumps when in manual mode and is the same as the Frequency when in Auto mode.
Rich
Just saw the *note at the bottom.
FREQANT, FREQE, SYNC can only be used when CAT cable is not used
- 389 Community Topics
- 53 Aurora
- 971 Maestro
- 945 Genius Products
- 307 Shack Infrastructure
