SETTINGS REQUIRED TO ENABLE TX1 FLEX 6600M
Mark Gottlieb
What are the most common settings, (MS), to enable TX1 RCA for a transverter? Is that the only setting that needs to be adjusted to activate that RCA output? I have a FLEX 6600M. Thanks
In the TX band settings, you can select to TX1 active, ALC, etc. for each band. This is saved in the Transmit Profile. The Default profile has all the TX and ALC settings unchecked.1
- 398 Community Topics
- 678 The Flea Market
- 191 SmartSDR+
- 392 SmartSDR API
- 95 Aurora
- 988 Maestro
- 963 Genius Products
- 353 Tuner Genius XL
- 317 Shack Infrastructure
- 222 Networking
