SETTINGS REQUIRED TO ENABLE TX1 FLEX 6600M
What are the most common settings, (MS), to enable TX1 RCA for a transverter?  Is that the only setting that needs to be adjusted to activate that RCA output?  I have a FLEX 6600M.  Thanks
  • Brian Denley  KB1VBF
    Brian Denley KB1VBF Member ✭✭
    edited November 2019
    In the TX band settings, you can select to TX1 active, ALC, etc. for each band. This is saved in the Transmit Profile. The Default profile has all the TX and ALC settings unchecked.
