TX1, TX2 PTT not working with DXEngineering Mag Loop power inserter
Ron K2RAS
Ron K2RAS Member ✭✭
My 6500 is connected to a DXEngineering (Pixel) amplified Mag Loop antenna.  The antenna power inserter has a 'key' connector to turn off the antenna preamp when the transmitter is keyed.  The voltage on the TX1 and TX2 connectors moves from just above 0 volts to about .6V when the transmitter is keyed.  This voltage is below the threshold to turn off the preamp.
I believe the TX1 connection used to unkey the preamp.  Is the 6500 working correctly?
Thanks, Ron / K2RAS
  • Dwayne_AB6A
    Dwayne_AB6A Member ✭✭
    edited September 2019
    In your Transmit Profile, have you enabled the port?
  • Ron K2RAS
    Ron K2RAS Member ✭✭
    edited June 2020
    That was it!  I don't do much with profiles, I never saw the matrix screen before.
    Thanks, Ron
  • Patrick
    Patrick Member ✭✭✭
    edited June 2020
    The tx set up is part of basic set up and would be remembered by the radio, even if you did not have a dedicated profile set up.
